Originally Posted By: 69GTX
I do think the synthetics will give some benefits in the higher stress environment you are seeing (ie high rpms during warmup). If you're doing 4,000 rpm or higher right off the bat, it could be trouble. I'd try to keep them in the 2000-3500 rpm range, the lower the better. One way to do that is accelerate up quickly, but smoothly. You can go plenty fast in 4th gear and the rpms on rural roads will be fairly low.
Buy the synthetic that's on sale. Stock up a bit when those sales occur. PP/PUP, Castrol Edge, Mobil 1, QSUD, Valvoline Synpower, etc. are all good ones. The issue is more with your cold rpms than the oil. The 5w-20 oil will reach normal flow in 10 seconds or less down to -10 to -20 deg F. If outside temps are above 0 deg F a 10w-20/30 oil will probably warmup faster and give you better early startup protection....especially in the spring-summer-fall months.
Your truck is still under warranty so you are obligated to use the factory recommended grade of oil. I'd find the strongest 5w-20 you can find. Having a block/dipstick heater may not be a bad idea either....giving you more margin to work with. Even a remote starter would give 1-2 minutes more before you are in the vehicle. I'd be interested in knowing the long term effects on constant high rpm warmups. No doubt you'll make it well past the warranty period. But what about after that?
Originally Posted By: Bottom_Feeder
Pennzoil, Quaker State, Valvoline, and (I think) Castrol all cover the necessary Chrysler spec so if you want to go to a synthetic, I'd go with one of those. Mobil 1 does not.
PYB is fine stuff and is probably doing you well, but synthetic would arguably be better for those cold starts and no warming up.
Originally Posted By: Bgallagher
+1 If you are flying without warming up I would say a synthetic would be your best bet to give you the most protection. I personally like Pennzoil products but Valvoline and Castrol's synthetics would do just fine. Have you considered installing a remote start? You could start the truck when you get the call and the truck will be adequately warmed up
Originally Posted By: NavyVet88
+1 on the remote start up. Some may say it's not worth the investment if your just gonna be 45-120 seconds from jumping in the cab but imo that investment may be the saving grace for your engine. I'm pretty sure your not cranking and driving your truck in the same manner as stated before 4-5 times a day.
Thanks for the responses! The Hemi is powerful enough that I don't usually have to floor the gas pedal to get up to speed quickly, but sometimes I do hit fairly high RPMs (~3000-4000) when getting out the driveway, which is what concerns me.
I have remote start on the vehicle, which I try to use to turn on the truck while I get my clothes/shoes on, but it sometimes doesn't catch.
For winter, I do have a block heater, so there's that at least. I'm waiting for my local Canadian Tire to have a sale, and then I'll get some synthetic for my next oil change.
Originally Posted By: CATERHAM
Well at least your truck is spec'd for a 20 grade oil.
A synthetic 5W-20 isn't going to be much lighter
on start-up but a 0W-20 will.
And the best 0W-20s would be one developed
for hybrid engines which have similar harsh cold running conditions.
These oils are as light as you can get at typical start-up temp's. The Mobil made Toyota brand 0W-20 is what I'd recommend and you can buy it at any Toyota or Lexus dealership.
Yes it of course doesn't have Chrysler approval but it is what I'd use.
The local Toyota dealership is about 100MI from me, so I'd be more inclined to use something I can find in Canadian Tire or NAPA or my local auto store. If the opportunity does present itself I will try to inquire how much they charge for their oil.
Originally Posted By: Pop_Rivit
There are a lot of vehicles that simply get started and then driven, even in cold weather. The reality is that the whole idea of a huge amount of engine wear at cold start is mostly marketing. Especially in your case-you're only a half mile from city hall. Just get in it and drive-your engine will probably outlive the rest of the truck as long as you do regular oil changes and maintenance.
Thanks for the advice!
