Longtime BITOG reader, first time poster.
Currently have 192k and some change on a 2012 xterra with a vq40de 4.0 V6. Owners manual calls for 5W-30 in most climates with a change interval of 3750mi. I change my oil and filter every 3k. Along with commuting ~30mi round trip I use this vehicle for towing boats and pretty frequent offroad use in a variety of terrain. Summer temps are hot 100+ and during duck season in the winter we get temps in the mid teens.
For the first few years of this vehicle’s life I used castrol GTX conventional, then at about 60k switched to basic synthetics (I.e. Mobil 1, Valvoline, Pennzoil, rotella gas truck). Variety of filters used mostly Purolator, K&N, Fleetguard, and Wix. The last few years has been a mix of Valvoline full synthetic high mileage, Pennzoil platinum high mileage, and rotella T6 multi-vehicle along with either a Wix XP or regular Wix/NAPA Gold. I also experimented with Schaeffer 132 Moly EP and Liqui Moly MoS2 additives over the years, but came to the conclusion I would rather use a fully formulated quality oil in the right viscosity than try to outsmart the engineers.
After doing my valve cover gaskets 2 weeks ago I am using Valvoline maxlife blend 5W-30 and a quart of Pennzoil high mileage syn blend with a Wix 57356 filter. Cams looked great when I had the valve covers off.
Is the current synthetic blend and regular Wix a solid choice for the temperatures, usage, and OCI I described? Will the blend hold up ok in my V6 for hot summer weather as well as winter use during duck season? If I went back to synthetic I would probably go with Valvoline extended protection high mileage as I like the VI and HTHS, as well as the boosted zinc and phosphorus vs regular maxlife. Admittedly I am a Valvoline fanboy but not opposed to Pennzoil. Not really interested in boutique oils they are too expensive for how often I change my oil, but I do use Amsoil severe gear 75w-140 in the rear diff!
Basically I’m trying to decide if I should stick with the syn blend and regular Wix, or if I should go back to full synthetic and Wix xp. Other recommendations are welcome but keep in mind I’m partial to Valvoline and Pennzoil with a wix or Fleetguard filter. Unfortunately stratapore is not available for my application.
