Well I just did - and it's pretty much exactly what he was saying.
Filled with more misinformation. There really is a "flat earth" society in
the oil filter world it seems.
Below - this is correct ... there is only one bypass valve in an oil filter.
And in this case, it's the bypass valve shown in this shot. The coil spring
just above the bypass valve is not used for any kind of bypass operation.
It's there to just keep all the guts of the filter tight inside the can.
Below - what he calls the "pressure spring" is not a bypass valve. It's
there to only keep the guts of the filter tight, and to seal the end caps at
the center tube against the ADBV and the hole at the dome end end cap.
He is forcing the whole filter media assemble up, which can not happen
under normal use conditions. He thinks because he can make it move,
that it must move in use ... that is not the case.
Below - this is not correct ... the whole media cartridge assembly inside
the can does not move, because the coil or leaf spring in the dome end
constantly keeps the guts tight from not moving. There are no oil forces
that will cause the whole media assembly to move towards the dome end.
Only a human's hand pushing it like he does can cause that. He shows the
actual bypass valve working, so don't know where he's getting this idea
that the big coil spring in the dome end is somehow another magical bypass
spring. I think Uncle Tony has been watching videos like this and just parroting
misinformation ... that's the main purpose of YT.
