Whose uncle is this Tony character? I don't understand why people watch junk videos, much less take them seriously.
Yesterday? So is that his 3rd video on his nonsense explanation of oil filter bypass valves?UTG posted an update video yesterday explaining his errors...
Why get it right when you can get triple the clicks walking back your awful takes by not knowing what the hell you are talking about!Yesterday? So is that his 3rd video on his nonsense explanation of oil filter bypass valves?
It must be a new click bait tactic for YouTubers ...Why get it right when you can get triple the clicks walking back your awful takes by not knowing what the hell you are talking about!
Uncle Tony knows more about engines and chassis than most of us combined here ever knew.What he does not understand is that the clearances inside an engine are what makes oil pressure. The filter being before the bearings means that the pressure will be the same on both sides of the filter unless it's plugged up
Are you sure about that?Uncle Tony knows more about engines and chassis than most of us combined here ever knew.
He understands everything but oil and filters? ... those really aren't rocket science. Clearly he's got major misconceptions going on with oil filters. Engineers would find lots of misconceptions and misinformation in his videos.Uncle Tony knows more about engines and chassis than most of us combined here ever knew.
But as is typical of almost ALL race mechanics and engine builders they know little about oil and filters other than what they think worked or broke and some basic grade temp and clearance rules.
This Forum is constantly and sometimes literally dissecting oils and filters to the n'th degree.
This is not 99.99997 % of the rest of the population.
Uncle Tony has one of the best automotive channels on YT that other mechanics and engineer might enjoy.
Especially relating to Chrysler products.
So if filters aren't bypassing - why as he stated - does he always find big metal particulate in the oil galleries during teardowns? (yes I have some theory and thoughts on this)
- Ken
I know for a while here many guys thought the Wix combo valve (on the cheap NAPA jobbers) worked by the cartridge spring compressing allowing the bypass. Didn't make sense to me without a large pressure gradient - something that didn't seem probable around the cartridge - though with the media absorbing and passing fluid - its more complicated than "equal pressure" around the cartridge. I worked with plastics engineers on mold flow analysis and assumptions and results after running an " all nighter" simulation using FEA results could be surprising. We used to place bets on outcomes. Engine fires up, guy does a big burn out at high RPM, then launches and goes down the track at redline. If that doesn't cause filter bypassing, then nothing will, lol.
Bold part ... bingo. He must be listening and absorbing misconceptions from others if he's claiming some of the things he does about oil filters.I know for a while here many guys thought the Wix combo valve (on the cheap NAPA jobbers) worked by the cartridge spring compressing allowing the bypass. Didn't make sense to me without a large pressure gradient - something that didn't seem probable around the cartridge - though with the media absorbing and passing fluid - its more complicated than "equal pressure" around the cartridge. I worked with plastics engineers on mold flow analysis and assumptions and results after running an " all nighter" simulation using FEA results could be surprising. We used to place bets on outcomes
He is likely not an engineer - so he has little knowledge of physics and fluid dynamics other that what he absorbed through decades of experience and likely chatting with those who DO know.
Thick in, thick out ... yes, but the flow rate when the oil is thicker increases the dP across the filter. In my drag strip with cold oil at redline RPM example, an oil filter will be producing lots of dP across the media and the filter will go into bypass in a use condition like that. And it will bypass through the bypass valve, not by lifting the entire media cartridge up. If that's how oil filters bypassed, like Uncle Tony thinks, there would be a lot of ADBVs swept onto the engine and causing major engine failures. The coil or leaf spring in the dome end needs to be stiff enough to keep all the filter guts tight and firmly in place during use. That's it's only purpose, it has nothing to do with bypassing oil or being a "pressure differential regulator" as Uncle Tony claimed in his second video.On the cold oil dragstrip scenario - thick in = thick out, so the pressure Δ may be less than you think.
Hopefully they are running a screen and not a paper canister - or on Lo-Po - twin remote FL1A
- Ken
Go back to my drag racing with cold oil example. Of course if engine bearings start destroying themselves, there will be debris in the oil feed to the pump. And I'd venture to say damaged engines that have debris down stream of the filter were being beat hard while that was occurring and causing the filter to bypass while it was eating itself alive. So yes, you would expect to see some of that engine damage contamination in the engine after the filter.He is correct on the major point he was making, and I will say it is eye opening and true that when many a motor get trashed at high rpm and load that the filter bypass is likely open I Recall him stating that the oil feed and galleries are usually all filled with debris from the carnage. That stuff doesn't get there if the filter is intact and not in bypass.
- Ken
I saw the video and was not impressed. Reading thru the comments several people tried to explain where he was wrong but he was not having any of that. His channel is just so so and I wish people would not make anybody on social media "an expert" because that is exactly how misinformation spreads.
