The bypass is there in case the filter gets plugged if I understand correctly, what would cause the filter to become plugged If oil changes are done on a regular basis ? I have a 2012 GMC with a 5.3 which calls for a filter with a bypass number of 15 lbs. I would like to go to a longer/bigger filter, PF63 which has a bypass number of 22, as long as I have good oil pressure is there any harm? As I have begun to research this I had no idea there were so many variations in oil filters. Thank you for your comments, Tom.
