Ford F150 with the EcoBoost engine, or the new 2025 RAM 1500 with the 3.0L Hurricane engine?I am highly considering getting a pickup truck with a dual turbo engine. Is there any issues I should be aware of? I would plan to not use it heavily. Will there be issues developing if the turbos are underused?
Think it means I need to drive it on the weekendWhat does "the turbos are underused" actually mean?
I'm curious why?If you're thinking Toyota Tundra with the new twin-turbo engine, just don't.
What I was thinking of was that if you are not going to have a load most of the time.What does "the turbos are underused" actually mean?
Regardless of load - the turbos still spin. The rate at which they spin will vary with the boost/load, but they still spin. I wouldn't worry at all about "underused" - that just means that the engine won't see heavy use - which is desirable for longevity on any engine.What I was thinking of was that if you are not going to have a load must of the time.
Wondering the same, because the Tundra is what I was considering.I'm curious why
Thanks. I just thought I heard that condensation could build up in them.Regardless of load - the turbos still spin. The rate at which they spin will vary with the boost/load, but they still spin. I wouldn't worry at all about "underused" - that just means that the engine won't see heavy use - which is desirable for longevity on any engine.
So 93 octane fuel gives better gas mileage?My work truck was a 2011 F150 3.5 Ecoboost. When I retired, I had driven the thing 154,000 miles. Not one problem. Always M1 oil, 5000 mile oil changes and regular service. My last drive in the thing was my typical 1350 trip with cargo. Ran like a top. I kind of miss it. Loved the power! It ran like a champ on 93 octane, with both better MPG and tire spinning power. Made the more expensive fuel worth the expense by cost per mile.
Turbochargers all (water cooled or not) get hot enough to "coke up" the oil on the exhaust side of the shaft. More modern turbochargers are designed to accommodate this coke (carbon) buildup and still function. Older designs would fail with as little as a few thousandths of an inch buildup. HOWEVER, owners are far better off choosing an oil that does not coke up the turbo hot section.
One proven way is to simply use M1 oil and change at 5000 mile intervals. The turbos will never coke up and will provide excellent service.
That would be one I am talking about, but Toyota has them now too.By writing dual turbos do you mean Ford Ecoboost? What years specifically?
In that 2011 Ecoboost, it improved highway MPG by at least 2.2 MPG. Sometimes more. There were times where I could get better than 21MPG highway, with 93. It depended on the time of year and location. To be more specific, 17MPG was solidly the norm with 87 octane, and 19.6 was common with 93 octane.So 93 octane fuel gives better gas mileage?
Even under light load they might spin 75k RPMs. Under heavy load, it could be 125k RPMs. Zero concern about "not getting used."The rate at which they spin will vary with the boost/load, but they still spin.
