Shel_B
Site Donor 2023
- Joined
- Aug 7, 2020
- Messages
- 5,166
This is what Scotty suggests:Check out Scotty KILMER On you tube, HE Will show you a replacement to convert the Toyota cartage filter to a spin on one
Baxter Performance - Oil System Solutions
Baxter Performance products are not just accessories, but components that will help extend the life of your vehicle’s motor. Find out how today.
baxterperformanceusa.com
I've looked into it for my Camry. It's a spendy item, about $200.00 if I recall correctly. It might be a worthwhile purchase for some folks.
One issue to be considered is that most any filter you use would hang lower than the original (if your car has a vertical canister, as on the Camry) and could be damaged in certain situations. Another consideration is the replacement filter itself. Getting one that physically fits shouldn't be a problem, but getting one that has the correct bypass relief valve pressure will take a little research. There are various relief valve pressures available, and I don't know what's appropriate for the different Toyota engines, nor do I know how different relief valve pressures will affect performance and engine safety. Maybe someone reading this has the information and expertise.
So, in conclusion, it could be a worthwhile option, just do your homework.
