This is one of those old engine designs, it has flat tappets with shims over the lifters. These engines are known to last a half million miles with the older higher ZDDP oils. The procedure to adjust the valves for wear involves buying an expensive set of shims, obviously something I want to avoid.
The manual calls for 5w30 but there is a more recent TSB that says 5w20 is OK. I currently have 50k miles and have used nothing but 5w30 Walmart Synthetic.
Looking for a better oil that will protect the valve train as well as deal with multiple short trips on a could engine.
