Mewbs
- Joined
- Oct 3, 2023
- Messages
- 865
To continue on. I just recalled from memory the PH/XG3600 being an 8PSI filter from the hayday. That Fram 3600 filter commonly used on Ford applications, I meant no emotion whatsoever and I was going on based on fact I wasn't updated. You can possibly use the Motorcraft FL400S if you chose to get crazy. I can recall Baldwin/Hastings B243 being rated as an 8PSI filter as well. That's how I remember it being, I was unaware about the recent enhancements made to these filters so I apologize if I came off brash.
So if I stand correct, you might want to look at the temperament of your post before throwing the gavel my way. Tsk tsk
My apologies as well if my reply did came out blunt and offensive, after all we're all here to share information and experience. I appreciate your input regardless to adding to the discussion.
During my research I only narrowed the oversize filter selection to retail store available products. I did not look into industrial-fleet market filters since getting them would be through some sort of dealership or online store having to factor shipping cost as well.
It would be cool to look into what the offerings are there as I heard good things about FleetGuard, Donaldson and Baldwin in the trucking industry.
Good work! It appears this Boss is made in March 2021 & would be old stock that claimed the 15,000 mile rating rather than the latest 20,000 mile rating. I remember an instance here that mentioned about the ADBV tearing but don't know if it was a batch issue or how widespread it may be. The base plate is pressed against the ADBV to create a good seal but if the sharp edges of the spin on center could tear them. If you carefully stick your finger in the hole to feel around & it feels like it's not cut through or anything then it should be fine. If you can swap out for the 20k version i'd go that direction just double check if you see anything out of the ordinary at the ADBV.
Think I'll run it than returning it, the base plate biting into the ADBV doesn't seem very deep from what I inspected.
I did watch a few videos of the Purolator Boss at WhipcityWrencher and they all appear to have some sort of slits or impression against the silicone valve against the baseplate on his inspection videos.
All the other Purolator Boss filters I saw at the local Advance Autoparts were all rated at 15,000 miles on the package printed. So it seems they may not be moving product really well, at least in my area. Most of the Fram Titaniums I see on the shelf there are mostly non-wire backed unless you got lucky and find some old stock in the rear stock on the shelf. Meaning Fram might be moving product more than the Purolator, specially looking at the price difference of the two.
I got the efficiencies for you on the Purolator Boss oil filter. Keep in mind that Purolator is being honest while the other companies aren't divulging this information.
https://bobistheoilguy.com/forums/threads/purolator-pbl20195-specification-sheet.375618/
You didn't have to go above and beyond to get official spec sheets, I do appreciate the extra effort you went to get that information.
Not sure how I feel about the filtering rating. Its honest which I do respect but doesn't make it any different to any high flowing OEM filter you'd get from Toyota and Honda which again their particulate filtering ratings are not known officially and have been said to favor flow over efficiency which is a respectable design choice given their track record of engine reliability.
Usually aftermarket filters at the premium market segment are rated for high filtering efficiency at extended mileages. This sorta goes against that idea and mindset. I now see the Purolator Boss filter have at hand more of a high flow extended mileage filter given this information shared. Thank you.
Would I run it? Probably throw it on a family Toyota to see how it holds up. Is it worth a few dollars more than the equivilant sized Fram FS3600? probably not after learning this. Both filter designs have their tradeoffs, one favoring build quality for extended life while the other combines flow and filtration efficiency. The Fram Titanium can could be thicker if I was to complain about it.
The build quality of the Boss filter is heavy duty and well finished which I liked about it. The official filtering rating kinda contradicts the target market this filter is aiming for in which I personally favor good efficiency & design that could last multiple oil change intervals as a cost saving or break even feature in relation to cost per filter and filtration life.
