Due to the filter's location (see photo), I expected a sea of oil to run down the block. I prepared the area underneath with disposable towels, etc. When I pulled the filter off, not a drop came out-- inside or outside the filter. Can't really see much at all inside the filter and if I turn it upside down, nothing comes out. In all my years of changing oil on various makes/engines, this is a first for me; there is always some mess or residual oil hanging around.
I'm a little intrigued by this. Filter in question is a Fram Ultra/XL (whatever the expensive gold can is called) and the ADBV appears fully functional. Either this is a really great design or something is wrong. Which one is it? Engine makes no startup noise and oil pressure comes up quickly as best as I can tell (oil light immediately shuts off). I should note that the filter was changed within an hour or two of shutting down the engine. There was zero cleanup done before taking this photo other than wiping off the gasket mating surface which had some light residue on it.
