Wow we're drifting a bit, this time the drift wasn't caused by me. LOL
I was looking for an answer for this hopefully someone with an engineering or mechanical background and not from a Google search.
I'll ask again.
Just out of curiosity how much more of a safety margin would a 30 grade oil provide over a 20 grade oil when a radiator hose lets go? Is there any testing that can be done to calculate at what extreme bearing temperature the different thicker or thinner oils have a real world advantage? Would the safety margin you mentioned in another thread allow you to run the engine any longer w/o damage using a thicker, or thinner oil? Just to be fair lets compare oils from 2012, since most of us don't have 10 or 20 year old oil in our stash that we use in our cars. Thanks
Hopefully an answer to my question will help me become my analytical self, with a
The higher vis oil will not provide much advantage in the situation you are describing but that's not why it was spec'ed in the first place.
Thicker oil film won't provide an additional margin of protection if things go bad? Is that what you're saying? Thanks
Engine oil is not intended as a coolant for overheating components. If there is any benefit of the higher viscosty in this situation, it wouldn't be by design.
Oil does cool engine internals, however it is not the same as coolant. My question is what happens if something goes wrong? Does the thicker oil help at all?
