Not sure about engines but for transmissions NYC Sanitation was one of our benchmark difficult applications at Allison. One of the sites used to develop TranSynd.
Why exactly is it that he has joined an oil forum? Why have you joined an oil forum? To extol the virtues of doing things the way you have always done them?
This guy advocates his way of thinking because he saw a video on the FordTechMakuloco channel? Brian is a great mechanic but he has absolutely zero OCI data on these two engines. Completely anecdotal beyond the fact that one looks better taken care of than the other. There is zero data on how those engines got to that point.
Perhaps @Navi should get some actual data on his vehicle or fleet and make an onformed decision about when to change the oil. That means doing oil analysis. If he brought data back that said, the fuel dilution on the motor is too high for his comfort level after 3K, fine, I can support that. But taking a shot in the dark based on a YouTube video, that's not how we roll around here.
So I just sit back and laugh every 2 weeks (probably every oil change) when the “latest and greatest” 3k oil post pops up, with dubious claims made from a 2-week test based on a $38 UOA from a lab that generates a lot of data that is questioned for its accuracy.![]()
Which company would you recommend instead of Blackstone?He's done UOA's, but they were with Blackstone, so the fuel dilution figure of course isn't accurate.
Pretty much any of the others. Oil Analyzers, Wearcheck, the WIX/NAPA ones, CAT, etc. You want a place that does gas chromatography (GC) for fuel testing, not an inferred % based on flashpoint.Which company would you recommend instead of Blackstone?
I like OAI/Polaris, but as @SubieRubyRoo noted, any lab that does GC is a fine choice.Which company would you recommend instead of Blackstone?
Thank you for the info! I would concur that the XL would be a good choice given the conditions for the OP.All the top line up have plenty of anti-oxidants and detergents/dispersants. Base oil selection is important as well, but any ester/PAO/AN or even a clean Group III base oil would be fine in this application. No Amsoil oils are only ester. No such animal.
In this situation, the XL line up would be more than fine, which is a high additive Group III oil. But OP seems to want to stick with Walmart oils.
You can go ahead and search on Google and Youtube to learn about sludge if you are not knowledgable. In "severe" and "extreme" duty driving one challenge is sludge.
Sludge is the main reason I change the oil every 3000 miles. Most notably I found the best oil to be one with the most detergents. Through my testing and reviews of VOAs I found the best value oil to be Quaker State High Mileage Full Synthetic but the best oil to be the Valvoline family which has detergent rich formulations.
For Ford Ecoboost engines I use Valvoline Full Synthetic Max Life. For the GMs I use Dexos rated Quaker State High Mileage Full Synthetic. Both are detergent rich oils.
My real life experience is the livery business in and around New York City. I have had engines sludge up in the past. When I first started in the industry I did 5000 and 7000 mile intervals and through hard lessons I learned 3000 is the way to go.
Here is one video from the Ford tech of a sludged engine. However there are countless videos and articles which can be found with a Google search. If you ask any mechanic they will tell you to change at 3000 miles and why? Sludge!
We all have different situations. If you lease or plan on selling before 70000 miles a 3000 mile interval may not matter to you. However if you plan on keeping the vehicle above 100000 miles or describe your use as "Severe" or "Extreme" duty trust me...3000 is the way to go.
Very curious about your fuel dilution in the Ecoboost--are you performing UOAs? If so, which company? Is this a 3.5L, 3.0L, or 2.7L?For Ford Ecoboost engines I use Valvoline Full Synthetic Max Life.
Completely agree. The OP has failed to consider the lost revenue of his downtime.He refuses to acknowledge it, because of the “excessive cost” to buy HPL, compared to changing oil and filters & equipment downtime every 2 weeks.
And re: the hobby comment above, changing oil on fleet vehicles that could be out making you money is not a hobby. It’s pure expense and lost revenue.
Why pitch HPL? You are a mod.Completely agree. The OP has failed to consider the lost revenue of his downtime.
Downtime is why HPL has so many big fleet customers. If you can double (or quadruple, in some cases) your OCI, then your equipment stays in operation longer, avoids the downtime for routine maintenance, making you money.
HPL’s lubes allow operators to do precisely that.
But those operators can do the cost/benefit analysis that has eluded the OP.
The other thing I’ve realized with HPL is that if the machine is on say a 6 month PM program, and when the PM comes up if there are factors preventing doing the PM, if you have properly selected the PM intervals, there is almost zero risk to extending the interval for a period until it can be caught up.Completely agree. The OP has failed to consider the lost revenue of his downtime.
Because HPL was specifically mentioned and I’ve seen proprietary data where operators have done just that. I can’t disclose the industries or entities involved, but that is HPL’s bread and butter - big fleets, longer in service time, with data to back up the extended intervals for those customers.Why pitch HPL? You are a mod.
Any good synthetic would do the job. Keep it neutral man.
Well, I assumed the OP was committed to WM oils, as he clearly stated.Because HPL was specifically mentioned and I’ve seen proprietary data where operators have done just that. I can’t disclose the industries or entities involved, but that is HPL’s bread and butter - big fleets, longer in service time, with data to back up the extended intervals for those customers.
But you make a good point, Pablo. AMSOIL makes excellent oils for extended service life, and the OP would be well served by considering AMSOIL as well. I have used AMSOIL products; Fuel system cleaner, grease, oil, transmission fluid, gear oil, Metal Protector and, of course, engine oil, and been very pleased.
The OP would be well-served to consider AMSOIL when, and if, he ever figures out the cost of his down time, and starts to analyze the performance of the oil in service with data, instead of fear.
My apologies for sounding like I am promoting one product over another when my point was: consider the cost of downtime, and not just the cost of the oil.
