Quote:
Quote:
how does mobile 1 compare to pennzoil platinum? better? the same? the price is about the same and i was thinking mobile 1 might have a better name... dunno
Just drop some in and test it out. PP quieted my noisy fuel pump by atleast 50% if not more and evened out my gas needle which was broke up top meaning it would get stuck at way past full when you fill it up for like 50 miles then drop down 3 marks all of a sudden. Believe it or not, the PP slowed the drop down to where it touches all the marks and gets stuck for less time up top (still get stuck which now is a good thing) Also the noisy fuel pump, well before you could hear it outside the minute you walk out but now its not as priminent to the point where you have to bend down and really loko to hear it. Now, the question is would M1 do the same thing and again, I would have to try it out to see. All I know is PP is really well tested. Look and click on the link below. I gave it a try and it has helped in areas other then revving and FE. I might try M1 to see if it can help me in those areas in the future. Oh, one other thing I reported was that PP feels heavier and that might have helped the low end torque a bit when just lugging around town. I still feel that way because this heaviness I feel down low does help with take offs. Everything else was maintained from the MC I came off of like highway king speeds/rpms and spirited driving when your RPMs stay at 2000 rpms and above. You gotta know I cruise around down at 1500-1700 rpms so it's real low until you want to start competing which starts at 2000 rpms.. as far as protection, I have UOAs here and the fact that it feels heavier down low just makes it feel like it is protecting real good..you just gotta try the oil to see.. i would have never guessed it would help me with noisy fuel pump and gas needle but it did and that made it more worthwhile then just the better low end grunt (did NOT change gearing, just made it better) and protection..hope that helps..
