I was debating in my mind the detergency/disperancy difference... and I'm glad you cleared it up. Please clear the other issue up, that being the nature of detergency in motor oil. Does it actually mean cleaning or does it mean the prevention of getting dirty?quote:
Originally posted by Jimbo:
Dispersancy is the correct term. Detergent and dispersant tend to be confused. There might be a good reason, some additives may do both. Aircraft oils typically are "ashless dispersant" , which is a type of non-detergent oil. The dispersants are non-metallic to reduce the possibility of spark plug deposits, since aircraft piston engines have large clearances and burn a lot of oil.
Thanks for your input!
