How's that? Or, what are those standards that make Shell the golden one?Shell is probably gold standard when it comes to engine oils.
Would you care to list the actual criteria you are referencing? And, please no Project Farm “testing” as criteria.Shell is probably gold standard when it comes to engine oils. For the price and performance it handily beats HPL, Amsoil type boutique brands across several criteria.
Please share this test data/criteria.Shell is probably gold standard when it comes to engine oils. For the price and performance it handily beats HPL, Amsoil type boutique brands across several criteria.
Don't be so hopeful. He may be legally bound by NDA.Please share this test data/criteria.
I mean yes but also besides that I think new camshafts suck.Camshaft wear is often just caused by poor metallurgy in some engines. No matter what we do with it 5k OCI usually helps on preventing caked up piston rings from degraded base oil or additives package, but rarely help on Camshaft, timing guide, or timing chain wear. Some engines just have poor quality parts. Probably using 0w40 helps, just like the bandaid on GM engines
Lake Speed is better than Project Farmville - at least he tests on a real engine, and doesn't compare apples to oranges or mass market oils to boutique onesWould you care to list the actual criteria you are referencing? And, please no Project Farm “testing” as criteria.![]()
Just take a look at all the UOA. For example signature series. Outperforms most off the shelf oils with same viscosity and approvals.
It is just the same within the error bar, how people drive, weather, and samples variant. It is wear number/Sqrt( number of sample-1)
Signature Series has ZERO approvals. Sorry I couldn't resist correcting you. But that doesn't make it a lesser oil.Just take a look at all the UOA. For example signature series. Outperforms most off the shelf oils with same viscosity and approvals.
Lake Speed is better than Project Farmville - at least he tests on a real engine, and doesn't compare apples to oranges or mass market oils to boutique ones. My comment was based on price as well as performance.
All said and done PUP is a very good oil indeed.
Like I said he doesn’t compare apples and oranges but the performance comes very close at a lower priceI watched the whole vid. Couldn’t find any data on PUP out performing HPL, Amsoil or any other oils in fact. Did I miss it?
Nothing wrong with PUP. Actual performance data is hard to come by and I’m always looking. Amsoil probably provides the most.Like I said he doesn’t compare apples and oranges but the performance comes very close at a lower price
And given oil is relatively cheap, if I'm extending the intervals, give me Signature Series.Nothing wrong with PUP. Actual performance data is hard to come by and I’m always looking. Amsoil probably provides the most.
The signature series spec I’m seeing at least in India would work for older VW but not the newer ones with emission controls. A5B5 or ilsac gf5 based. Else it is a fantastic oil.And given oil is relatively cheap, if I'm extending the intervals, give me Signature Series.![]()
Very close by what metric? You made a rather bold statement:Like I said he doesn’t compare apples and oranges but the performance comes very close at a lower price
SureshR said:it handily beats HPL, Amsoil type boutique brands across several criteria.
GTL also has poor solubility, albeit it's a bit better than PAO, but that's really not saying much, that's why carrier oils are used. PAO is blended with AN and/or Ester primarily to offset its seal shrink tendency, if it was just for solubility, a lower group base like Group I/II would be used as a carrier. Remember, GTL is ultimately just a Group III base (hydrocracked), but it benefits from having less wax in it than competing, more conventional Group III offerings, improving its cold temp performance, and it also has lower Noack. Basically, it offers closer-to-PAO performance without the price tag, and without the seal shrink issue, nobody is using it because of its solvency.For the price, GTL oil performance is hard to beat. The stability and solubility to additives in GTL is already great, unlike PAO that still need Ester. However, PAO is still more stable than GTL.
Is it called Shell Ultra Helix in India?The signature series spec I’m seeing at least in India would work for older VW but not the newer ones with emission controls. A5B5 or ilsac gf5 based. Else it is a fantastic oil.
And then again still limited by the life of the oil filter - which a standard paper cartridge just doesn’t have enough of. Maybe just change the filter and top up the oil?
