Two things I hate is 0w20 in a V8 and an unlocked footlocker.
OK fair enough. Unfortunately the vehicle doesn't give me that information.You have proved that in your case, it may very well be good enough. I just ask about the oil temps because those can vary wildly between vehicles in the same operating conditions.
Said boat anchor does 0-60 in 5.4 seconds (per car and driver) and runs a 14 second 1/4 mile in a shoebox shaped pickup. Not stressed? You’re referring to almost 500 ft-lbs. of torque. People often have a distorted perception of power output due to technological advancements. Many are accustomed to seeing large hp/liter engines making impressive power with small displacement, while large V8s reaching 400-500 naturally aspirated are dismissed as insignificant. IMO an engine doesn’t have to make Lamborghini or Ferrari level power to justify a higher viscosity oil.I’m one for thick oils when necessary, but let’s not pretend the 6.2L is that power dense. People keep mentioning that. It isn’t. Many other engines make more HP/liter. The 6.2L makes under 70 hp/liter, it’s kind of a boat anchor. The engine in our Carnival makes about 84 naturally aspirated.
I’m not ragging on the engine. It’s huge and makes good power, but it’s not that complex and certainly isn’t stressed.
Basically, there is no meaningful downside stepping up from a 20 to a 30 in this scenario. This is especially true if experiencing fuel dilution like that; as the operating temp viscosity of the oil isn’t even a 20 grade oil anymore. It’s below the recommended grade now. Has the engine blown up yet though? Funny thing to wait for. Maybe it just wears out a little faster. What if that is real. Why ego a 20 in this context? Because any reasonable person looking at the evidence will say stepping up a grade is required to meet the manufacturer’s recommended grade in this situation. Unless you are in very cold winters, which still raises the question of longer warmup times and fuel dilution still being an issue or possibly worse in the winter; so to win both worlds get 0w but in a 30 grade. Where’s the lie?Its old school but it works. 10cSt at operating temperature is the way.
For my wife's car I was running 20wt in it till I found the oil was losing viscosity due to fuel dilution and other factors, one test the oil was 4cSt.
That's probably part of the reason Hyundai 2.0L Nu engines were doing spontaneous disassembly on the freeway.
As long as all the engines are always made perfect then 20wt works.
Turbo on that one?13' CRV AWD K24 engine / 614,934k / original owner / New York 20-90 degree temps on average / cap says 0W20 / use 0W20 - 20 k synthetic / 3k OCI intervals with OEM filters / Still going as daily driver
Which is never.I go by a jeep service bulletin that boiled down to make sure you don't use oil that gets thicker than 6,000cP at your coldest temperature expectations.
That's probably around -20f here. If it gets that cold I'm not going anywhere except to the wood pile with my wagon
Yeah 20wt works great, till it doesn't.
Not always, seen many accident scenes with many older vehicles holding up a lot better than newer ones, occupants included. 1 instance, I worked a very large pile up on the interstate, whiteout at 70mph. I saw a late 90s K1500 get smashed between 2 semi's; 1 semi going hwy speeds, the other almost stop and truck in the middle. Front end was bad and it bent the frame down behind the cab but that was all for the truck, folks injured but not serious. Same scene and 2010ish truck was caught the same smashed in, not as lucky.Older heavy thick cars are not as good as newer cars in crashes. They put metals on not so important place, just added weight.
I like that some newer cars even use aluminum plate on the trunk, hood and probably door skins.
Love these posts. I towed this past year up to the highest city in the U.S., Leadville, Colorado (10,000 feet) pulling a 5,000 pound travel trailer in 90 degree heat using 0w20 in my 2023 Silverado (5.3). That's what the manual states-that's what it gets.
Don't think your mini van will see conditions like that-especially in your part of the U.S.
Point of order Alma Colorado (South of Breckenridge) is higher at 10,361
Yes-the difference in that Leadville is the highest Incorporated City in the Country.
I’ve run AMSOIL Signature Series 0w30 and ESP 0W-30 in my 21 Wrangler 3.6 and the oil pressure is exactly the same as 0W-20. It gets pretty cold here. The oil pump is controlled for a low rpm pressure and a high rpm pressure. You may have something else going on.I’m going back to 0w20 from 0w30. My jeep has 11k miles on it and I went to 0w30 for better protection. I’ve done some research and that sounded like a well thought out plan. Well after driving for a little bit and now we are in really cold weather when ever I drive my oil pressure hunts up and down constantly. Never did this on the 0w20. More than likely I think it’s the oil more than a mechanical issue. Gonna change that first and see. With everything I’ve read I’m thinking more of the failures with the 3.6l were from bad manufacturing when it was made with bad materials than the oil. I’m gonna try the 0w20 again and see if that helps.
