Originally Posted By: Mr60hertz
Skyship - it burns it, doesn't leak. Are you suggesting replacing the PCV with your CCV comment?
Originally Posted By: skyship
Originally Posted By: fauxchemist
First of all your consumption is nothing/very little. My thoughts are- Why are you trying to slow consumption by going to a thinner oil makes no sense. My guess is, if switched,consumption would hold steady at current rate.
I agree it won't change, you have two choices, think about moving to a 30 grade or if you are leaking rather than burning then an HM 30 grade. My guess is that would half the consumption if you used a 5/30 HM, but make sure you don't have a blocked CCV.
GENERAL NON POSTER SPECIFIC REPLY:
Some engines have a crankcase valve some don't, I always mention it just as a precaution because it is a problem area for some engines.
With oil brands you get what you pay for and good oil that lasts longer (M1 0/30 is a good oil) will cost more. Many of the smaller engine oil companies in the US have poor quality control standards and their spec wanders. Valvoline is one of the few the German labs think is OK and it does have some franchise related approvals for the long OCI's that must be recommended by those companies in the EU.
The saving in fuel between an 0/20 and 0/30 of the same quality is often so small it can't be detected and probably less than the extra cost of top up oil, so changing from a 30 to a 20 to save money is a daft idea.
