What are the recommendations for Supercharged applications? I believe OP has Harrop Supercharger on his 3UR-FE. According to Harrop:0w20 is the recommended oil in the Tundra...no trouble at all, it will run hundreds of thousands of miles on 0w20 with no issues. Just pick your brand.
I did not see the OP's mention of supercharger in the original post until you mentioned it. I have no idea how that affects the oil application.What are the recommendations for Supercharged applications? I believe OP has Harrop Supercharger on his 3UR-FE. According to Harrop:
So not quite the stock engine that the original owners manual was made for... Or are you saying that extra boost does not accelerate wear on the rest of the engine, and an oil grade made for stock application will do just fine while battling extra heat from the supercharger, and extra heat from the sunny Texas?
- Stage 1 @ 6.5 psi – 478hp / 463 ft-lbs (+160hp / +88 ft-lbs overstock)
- Stage 2 @ 8.5 psi – 513hp / 514ft-lbs (+207hp / +136 ft-lbs overstock)
- Capable of over 1000hp+ with supporting engine modifications
If it were my equipment I would feel a lot better moving up a grade : 5w30.2020 Tundra S/C'd Harrop running ~6psi
31k miles on motor - 5k on the S/C
using Kirkland 0-20 change every 5k
I don't tow or haul.
any benefits of moving to another oil or weight? if so, which one?
Looks pretty good, but I would still monitor it occasionally, in case those wear numbers decide to take-off by the time you reach 50k-70k on the motor.changed oil before adding Harrop S/C.
tuner did ~18 dyno runs tuning it for stage 1 and then stage 2.
I drove it for another ~3000 miles after the tuning.
not bad.
I'm sure there are better oils, but at $2.6/qt & i change it every 5k.....this'll do.
