Well this is BITOG and we are on page 4 already so.....
If it's not totaled already, it will be.
Seriously just check everything before you go. Check when you fill up. Maybe bring a quart of your favorite oil to top off if needed. Has it burned oil before? I was going to say the same as great opportunity to run some BG44k or Gumout Multi-system.
Pre flight checks for me are mandatory so oil, washer fluid (for expected temperatures), air pressure and tread depth (also the spare tire), clean windows inside and out, rain repellant on outside, check all lights. I do all those on a normal basis so if I need to go somewhere in an emergency I can go. All the above takes me about 5 minutes as it is at a good level.
My daughter was headed back to school next morning so all those were done. Tire pressure check showed one low, not at TPMS trigger yet. Nail in tire but had time to get it fixed so I wouldn't need to worry.
