If you change the oil before the road trip, your car will be fine. If you change the oil after the trip, your car will be fine. Pick which ever make you sleep better. If it was my car, I would change the oil prior to the trip
If you'll have 3000 miles on it before leaving, and then put another 3600 miles on it over the trip, then you'll have 6600 miles (call it 7000) on it after the trip. Being the 3600 miles on the trip will mostly be highway, and depending on what oil and filter you're using (what are they?) and any oil added over the trip, I'd say putting 7000 miles on the oil isn't anything to worry about. If you're worried, then just change it before you go. Edit - also since you drive it around 1000 miles a week, it's obviously not a short tripped car, which means the level of condensation and fuel dilution is probably very low and a good thing to help extend oil life.I do 5k OCIs. We leave later next month, going from NY to TX (with a stop in GA) and back. Google Maps estimates this trip to be 3,600 miles. Idk how much driving we will be doing while there but I'm sure it will be less than our work commutes.
Speaking of, We typically average about 1000 miles driven for our commutes to work every week, so I estimate there to be about 3k miles or so on the oil between now and when we leave. The possibility to change it at my destination exists, but I was wondering what the BITOG wisdom is.
A) Change before the trip (about a 1000 miles early give or take)
B) change at destination (over 5k on oil, probably over 6k, but it's 1800 miles of highway)
C) change when home (for those who like to live dangerously?)
Veh Miles 31k
OCI miles 11.8k
filter TG
oil brnd ST
oil grade 5w-20
oil base conv
Alum 5
Chromium 0
Iron 9
Copper 6
Lead 0
Tin 0
Moly 39
Nickle 0
Manganese 3
Silver 0
Titanium 0
Potassium 0
Boron 42
Silicon 38
Sodium 3
Calcium 1396
Magnesium 435
Phos 758
Zinc 876
Barium 0
Vis at 210F 54.0
Vis at 100C 8.49
Flash Point 440
Fuel Antifreeze 0
Water 0
Insolubles .2
Why did you buy the long life products ?Stuck in my old ways despite only being in my 20s lol
I'd go from Key West to Anchorage and back with that sump. Bring in a couple of quarts for top offs. OCI will be south of 15K, which is reasonable for that engine/oil combo, on the highway.Again - he should do what he wants. But what he wants and what the engine needs are two completely different things.
I use euro because it’s the only 5w40 I can find at Walmart, and I used fram enduro because I wanted to do extended drains but I’m still stuck in my waysWhy did you buy the long life products ?
Thanks, and the 1uzfe don’t need no top offsI'd go from Key West to Anchorage and back with that sump. Bring in a couple of quarts for top offs. OCI will be south of 15K, which is reasonable for that engine/oil combo, on the highway.
I'm sure he would like to make it back home before the car blows up...a mid-trip stop at Iffy Lube would make this less likely!Making a lengthy trip in a 30 yr old vehicle is a win in itself regardless of mileage involved. If time allowed I'm sure some on here would have a UOA done just to be sure... Besides, you could always swing by a Jiffy Lube mid-trip, bwahaha.
You really think that the engine is going to blow up just because he doesn’t change the oil on this trip? Surely you can’t be serious….I'm sure he would like to make it back home before the car blows up...a mid-trip stop at Iffy Lube would make this less likely!
More likely to blow-up when Iffy Lube leaves the drain plug loose.I'm sure he would like to make it back home before the car blows up...a mid-trip stop at Iffy Lube would make this less likely!
Lol My comment was meant as a dig at Iffy Lube! That they would make a safe return less likely.More likely to blow-up when Iffy Lube leaves the drain plug loose.![]()
My bad, I misinterpreted what you meant there. Now that I read it again I see what you were sayingLol My comment was meant as a dig at Iffy Lube! That they would make a safe return less likely.
He really doesn't need to change oil during the trip, and can probably wait a few 1000 miles after he returns.
That engine can run on olive oil, urine or spit just fine. Engine oil is overkill.Hey guys I’m looking for someone to either calm my nerves or recommend some advice. Going on a roadtrip tomorrrow around 800 miles one way, I have 4k miles on my oil. It’s a 1994 Lexus ls400 v8, running Quaker state euro 5w40, with a fram enduro synthetic filter rated for I think 20k miles. I’m 4k mile oci guy, but the reason I switched to a euro 5w40 and fram enduro filter is to be able to run longer oil changes. What would you guys do? The majority of the 4k miles is from my road trip to Colorado from Illinois and some city miles. My trip is going to be high speed 85mph the whole way. Would it be fine if I just changed the oil but not the filter?? Thanks.
