Hi everyone,
I got an answer from Red Line oils about what of those 40 grade oil is best to use in the OP car during the summer in Canada. Also, it's interesting that the tech recommends 10W-40 for summer use, but not for track use and at temp above
10°C / 50°F (the last sentence).
I'll keep this email for later use when people on here argue with me about 10W-XX oils and their lowest temp. use (pumpability).
Red Line oils tech answer and recommendation below:
I don't want to include the tech's name, but below I'm showing screenshot of the actual email which ends with the tech name and Red Line logo (not on the screenshot):
"All three are excellent, ester-based, high-HTHS oils, but for a summer-only, high-revving, 1990s Ferrari used in a moderate-to-warm climate, you can bias slightly toward the “thicker when hot, simpler when cold”.
The main advantage of 0W and 5W grades is cold-crank/low-temp pumpability (e.g., Red Line 0W-40 remains pourable down to -60°C and meets CCS at -35°C).
In a summer-only car, that extra low-temp capability is largely unused.
All three are “thick” 40s with high HTHS – 10W-40 is right in the sweet spot.
5W-40 and 10W-40 are nearly identical when hot; both have HTHS 4.4 and low volatility (6% NOACK). 10W-40 achieves this with a slightly narrower viscosity spread (10W→40 instead of 0W→40 or 5W→40), which generally means less viscosity improver and excellent shear stability over time – something I like for older performance engines that may see high oil temps and sustained revs.
Red Line 5W-40 gives a little extra cold-start margin, with virtually identical hot performance to 10W-40. Red Line 5W-40 could be considered with temps hovering around freezing
Red Line 0W-40 could be considered if you were regularly cold-starting near or below −20°C, for summertime driving the extra cold-flow capability is wasted.
Red Line 10W-40 would be the suggested product for mostly fair-weather street driving, occasional spirited runs, no track, starts above ~10°C.
Thanks"
Red Line email screenshot:
