Hmm interesting but it does say this: The lower viscosity oil also creates less internal friction, which frees up power and improves efficiency.quote:
Originally posted by 427Z06:
From a Ford site on the Ford modular engine:
"Because these engines run hotter with tighter tolerances, they have deep sump pans that hold nearly seven quarts of oil. Oil viscosities run much lower than we are used to with vintage Ford V-8s--5W20. Running anything heavier isn't healthy for the Modular V-8 because of its tight tolerances. The lower viscosity oil also creates less internal friction, which frees up power and improves efficiency."
http://www.mustangandfords.com/techarticles/mufp_0510_swap/index2.html
The Shelby GT500 and Ford GT engines are extremely low-volume production engines essentially hand built with aftermarket parts. As an example, I believe these specialty 5.4 engines don't even use the same bearings as the regular production engines.quote:
Originally posted by nomochevys:
Im curious why ford specs 5w-50 for the 07 Sheby GT500? The 5.4 is a modular engine too although it has a blower on it. I hope somebody can give a explantion for this cause I sure Im confused now.
0W-30 German Castrol is the only oil that Castrol makes that is a "True Synthetic". The 5W-30 Syntec is a Group III (not a true synthetic).quote:
Originally posted by Androdz:
What is the difference between 0w-30 and 5w-30??
Once again:quote:
I was been told the only reason because it requires 5w-20 was to able to meet requirements to get into some goverment deductions ans incentives. So that I should switch to 5w-30
I'm glad someone gets this point. Very few public roads will allow you to run WOT for extended periods of time.quote:
Originally posted by Geoff:
Still, "driven really hard" may not be as hard as you think. Sustained high speed driving or towing where the engine is consistently operating around maximum output would fit "really hard" use to me. Drag racing or street racing is very temporary relatively speaking, allowing the engine and oil to cool off. Not as hard.
Good advice. I actually would install some accurate oil temp & pressure gauges first to see if any additional oil cooling is even necessary.quote:
Put an oil cooler on the engine to be sure.
Still I dont understand the huge difference. There must be a reason and Im not a 5w 20 hater. The 5.4 in the shelby has a forged crank and pistons as well as forged rods if I am not mistaken. 4 valve heads too. It has about 8 lbs of boost. I am not a expert on these things and sombody correct me if Im wrong.quote:
Originally posted by dave1251:
nomochevys
Junior Member
Member # 10342
posted 03 September, 2006 19:14
Posts: 29 | From: Ky | Registered: Nov 2005 | IP: Logged |
It's not the same 5.4 has Fords other offerings.
I agree with buster on the red line suggestion.
