Hey all, long time lurker here.
These LFX engines are getting to be popular for swapping into other cars. I have one swapped into a Mazda RX8 that is built for track days and time trials and its great.
Factory oil for this is Dexos 5w30. Would you all recommend changing this at all for track use? I have an oil cooler, but haven't yet hooked up a sensor to monitor/record temps. Some LFX folks are running 40 or 50 weight but I'm not sure what data there is to support it as there still isn't a ton of data on these on track.
I have a case of Mobile 1 Euro 0w40 and a few quarts of Driven DI40 in the garage. Could/should I use that? Is it ok to mix different synthetic oils together?
Another question, the car uses a spin-on oil filter like would be used on an LFX Impala. I first used a Wix WL10255XP. On my first track day, it was somehow leaking and I couldn't figure out why. I ended up replacing it at the track with an AC Delco PF63 and it fixed it. The old filter seemed neither too tight or too loose and the seal looked fine when I took it off. Any ideas why this might be? Are Wix filters still recommended?
Thanks!
Thanks!
