Japanese
$50 site donor 2026
Please, don't use Mobil 1 Advanced Fuel Economy!Mobil 1 Advanced Fuel Economy 0W20
If you want use Mobil 1 Extended Performance, Mobil 1 ESP, Castrol Edge or Valvoline.
only if it's a European car with specific specs, not in this case its a Honda HRV. if you are a Mobil 1 fan person the AFE would work fine.Use Mobil 1 ESP 0W20 X2.
I wouldn’t change it earlyHello all!
I recently purchased a 2026 Honda HR-V. I am going to change the oil at 500 miles for break in, and I’m trying to make the VERY important life or death decision on which oil to use.
I have decided to use either Honda Ultimate Full Synthetic 0W20, or Mobil 1 Advanced Fuel Economy 0W20. Grok says that the Mobil 1 edges out on top due to lower Noack 10% V Honda’s 12%.
let me have your input!
There are no negatives to changing the oil early.I wouldn’t change it early
Honda actually doesn't want you to change the factory oil early. They want you to wait until the minder to do the first oil change. They use a special break-in additive from the factory.
The moly has done its job within the first several engine revolutions. You're not gaining anything leaving it in longer.I've also read that Honda uses high moly 'assembly lube' and recommends going the full OCI on the factory oil.
I've done an early OCI on every new vehicle I've ever bought although I have gone from doing one at 800 miles to now going about 2500 miles. Since I don't see many Honda's with engine issues at low miles I'd tend to believe the Honda engineers and I'd probably go about 4K on the factory fill if I bought a new Honda (split the difference).
No, you pulled 98.7% from the SAE J1985 standard. It's a standard reference value for efficiency (equivalent to a beta ratio of 75 (rounded).)Can't say whether it's the oil or grease mentioned above, but here's a link to the UOA I did on my Pilot at 494 miles. Lot's of wear metals, so felt good about getting them out of there.
I went with the AMSOIL Signature Series, as I've used their products for almost 50 years. Switching to HPL Premium Plus PCMO in the next couple of weeks and it will be my "forever oil" (I bought four cases on their Independence Day sale).
Had I to start over again, I'd probably just use a Mobil 1 product or Valvoline Restore and Protect, which both can be purchased at Walmart for $27/5qt jugs. I have a tendency to overthink things, and the Mobil 1 or Valvoline Restore and Protect, changed regularly, would have given 98.7% of what the HPL will (yes, I pulled that number out of somewhere the sun doesn't shine).
?There are no negatives to changing the oil early.
What’s not to understand about my statement? I’m saying that changing the oil early has no negative impact so you might as well do it.
So you have option of two oils for the same price, one clearly being better oil, but yet you will choose mediocre additive and base stock package because you don’t drive European vehicle?only if it's a European car with specific specs, not in this case its a Honda HRV. if you are a Mobil 1 fan person the AFE would work fine.
Also no harm in leaving it. Extra moly and additives will help seat rings there’s no harm in running the factory fill to the OLMWhat’s not to understand about my statement? I’m saying that changing the oil early has no negative impact so you might as well do it.
