it pulls from "sources" like wikipedia and reddit for starters. Not exactly cracker-jack level data sourcing ime for all things.Why not? Its nice to compare its results to my research.
Supertech/Kirkland for max OCI otherwise you’ll be motor oil poor and never financially recover.RIPyour car not doing first change at 224.327 (repeating) miles and not using Valvoline Restore and Protect 5W30.
Please, don't use Mobil 1 Advanced Fuel Economy!
If you want use Mobil 1 Extended Performance, Mobil 1 ESP, Castrol Edge or Valvoline.
If it's clean, there's no harm. But how do you know it's clean if you don't change it? At the very least, shouldn't you cut the factory filter open ASAP? And if replacing the oem filter, why not just change the oil?Also no harm in leaving it. Extra moly and additives will help seat rings there’s no harm in running the factory fill to the OLM
There could be the very real possibility of harm if you leave it in. Just look at the Toyota Tundra and GM 6.2 situations for example.Also no harm in leaving it. Extra moly and additives will help seat rings there’s no harm in running the factory fill to the OLM
I’ve pulled many vvt solenoids over the years with some interesting debris in the screens. I often wondered if it was machining debris.There could be the very real possibility of harm if you leave it in. Just look at the Toyota Tundra and GM 6.2 situations for example.
A lot of questions I ask Grok about this subject, it ends up pulling information from THIS forum with linksit pulls from "sources" like wikipedia and reddit for starters. Not exactly cracker-jack level data sourcing ime for all things.
We did experiment and ChatGPT told my faculty member to cite article that didn’t exist but apparently she wrote it.A lot of questions I ask Grok about this subject, it ends up pulling information from THIS forum with links![]()
Unless it happens to be one of the ruffled leaf spring, ripped media, misaligned ADBV versions. There "might" be a picture or two on this forum with them.When you look at the element inside of a filter it's hard to believe that metal particles large enough to be seen with the naked eye could pass through it .![]()
I'm going to assume that is not the norm .Unless it happens to be one of the ruffled leaf spring, ripped media, misaligned ADBV versions. There "might" be a picture or two on this forum with them.
I have seen some horribly, laughably, inaccurate answers from Grok. Particularly on technical topics, AI answers tend to be wildly untrustworthy. Look, some random guy on the Internet can be equally unreliable, but at least in this forum you get several opinions, most of which you’re accurate. It takes some critical thinking to discern the difference. In the end, you get an accurate answer, as well as avoiding a terrible mistake.A lot of questions I ask Grok about this subject, it ends up pulling information from THIS forum with links![]()
But did you feel better?I have seen some horribly, laughably, inaccurate answers................
Correct answer!Honda does NOT use any break in oil or additives at the factory. They do use a grease lube high in molly during engine assembly.
Honda dealership website:Can we please stop repeating this as if its proven fact? If someone proved this, I'd love to see the evidence, because last time I looked into it, the only "evidence" was a bit of moly in the used oil analysis of the factory fill, which of course is just assembly lube.
I also don’t just accept what it says blindly. I came here for input after using Grok as a part of the research.I have seen some horribly, laughably, inaccurate answers from Grok. Particularly on technical topics, AI answers tend to be wildly untrustworthy. Look, some random guy on the Internet can be equally unreliable, but at least in this forum you get several opinions, most of which you’re accurate. It takes some critical thinking to discern the difference. In the end, you get an accurate answer, as well as avoiding a terrible mistake.
I agree with that ^.Honda actually doesn't want you to change the factory oil early. They want you to wait until the minder to do the first oil change. They use a special break-in additive from the factory.
But you can use any 0w20. Nothing wrong with Honda OEM oil or M1 or whatever is on sale when it's time to do it.
