Mix GTL/III/IV.Group III or IV basestock?
GTL in Mobil ? Learn something every day..Mix GTL/III/IV.
For a LONG time.GTL in Mobil ? Learn something every day..
approx % of each?For a LONG time.
There is no way to know on any particular lot or container. SDS are unreliable in this aspect and often give wide ranges because it’s not germane to their purpose.approx % of each?
It is on msds. Not everything.approx % of each?
I just ordered some ESP x3 for $6.26 a quart from an Autozone deal they have going on.
Which 0w40 would y’all consider to be the best currently?
Awesome! M1 ESP X3 0W-40 will keep being great stuff.
There's hardly "the best". My personal favourites though:
M1 ESP X3 0W-40
M1 ESP X4 0W-40
M1 C40 GT 0W-40 (if obtainable once)
I'd love to add Ravenol RUP 5W-40 but you called for 0W-40 (if it really matters). But $$$$ currently.
Except M1 C40 GT all with VW 511 00 & Porsche C40 and the latter with BMW LL-04 & MB 229.51 & Ford WSS-M2C917-A.
Why would they?Don't forget:
Mobil 1 0W40 Supercar
Mobil 1 FS 0W40
Mobil 1 0W40 ESP
I wish they made Mobil 1 Racing in 0W40.
For one thing a 0W winter rating would be absolutely irrelevant to racing.Why shouldn't they?
Mobil seems to be using thin base oils and taking advantage of VM behavior and temporary shear to achieve horsepower gains. I think there are racing oils and there are racing oils. The Mobil offerings seem to be the type of thing you might use if you're sponsored and have deep pockets, vs a "racing" oil designed for maximum wear protection as you see from Redline, Motul, Ravenol, etc.For one thing a 0W winter rating would be absolutely irrelevant to racing.
Question on your comment to racing oils providing better wear protection. Is that in applications of high temperatures and high loads, or even in everyday usage? I've been browing around trying to learn about oils, and do "Race oils" always provide better wear protection, assuming you keep their change interval short, and mileage low? Is there a downside, outside of OCI, cost?Mobil seems to be using thin base oils and taking advantage of VM behavior and temporary shear to achieve horsepower gains. I think there are racing oils and there are racing oils. The Mobil offerings seem to be the type of thing you might use if you're sponsored and have deep pockets, vs a "racing" oil designed for maximum wear protection as you see from Redline, Motul, Ravenol, etc.
It's hard to generalize I think. For something like Ravenol RUP which carries actual approvals, for sure no downside. For oils without approvals, it's hard to say. It seems like that oils such as 300V should provide as good or better wear protection than the equivalent grade 8100 oil but you are taking Motul's word for it. A potential downside of these non-approved oils is they typically have high additive levels and maybe they would fail a deposit test in MB 229.5 or LL01, for example. I would not be that concerned if changing it very often.Question on your comment to racing oils providing better wear protection. Is that in applications of high temperatures and high loads, or even in everyday usage? I've been browing around trying to learn about oils, and do "Race oils" always provide better wear protection, assuming you keep their change interval short, and mileage low? Is there a downside, outside of OCI, cost?
Sidetracking us, thanks for the info about,,the Ravenol Rup oil, it is quite intersting. I've not seen a race oil with approvals.
Ravenol RUP 5W-40 (VW 511 00, Porsche C40, MB 229.51, BMW LL-04, Dexos), RSP 5W-30 (BMW LL-01, MB 229.5, VW 502 00 etc) and REP 5W-30 (BMW LL-04, MB 229.51 & 52, Dexos2 etc) while RCS 5W-40 (not to mention RRS, RSS, RSE or RFS 15W-50) doesn't come with any approvals, since it's probably too thick for BMW LL-01 and MB 229.5 as these approvals incorporate fuel efficiency targets. Their target market is different anyway. Racing, not anyone's daily vehicle, while RUP, REP and RSP accomplish both needs or many of them.
VST is another good option for you probably, but whether or not it is really any better than PP Euro 5W-40 is impossible to answer. It's certainly good on paper and has many Euro approvals. I think the tungsten is disappearing according to the chatter on the oil-club. The SN formula of VST has it still but it may disappear with the SP. No one has analyzed the SP yet and you can't buy it in the US yet since the entirety of the stock that Blauparts has is SN right now. I would note that it doesn't carry A40 if you care, but does have BMW/MB.The Ravenol oils are interesting. They seem to use Tungsten as their anti wear additivites, instead of others. Definitely a unique approach, I've not seen in my limited research. In my brief uoa Ive seen the folks are not so impressed. It does seem to have a positive following oil club.de.
