GDI is present in European engines for 20+ years. SP is way less stringent than any European approval.Even GDI?
Then why do you think SP came about in the US?GDI is present in European engines for 20+ years. SP is way less stringent than any European approval.
API SP is for the whole world.Then why do you think SP came about in the US?
Go for a run?Again, running, sex, do something and let people actually talk oils.
For trade laws, bilateral agreements, your local university is place to get answers.
“API is for the Whole World.API SP is for the whole world.
European manufacturers have their own approval process. It was discussed here, like 63864862836 times.
In the beginning of 90's when European manufacturers started with downsizing to small turbo engines, especially diesel engines, API simply was not cutting. They founded ACEA which was the starting point for manufacturers approvals which were built using ACEA sequence as starting point.
API SP addresses some issues around LSPI and timing chain. But it is very generic. LSPI in Asian and American vehicles (European vehicles rarely have issues with that), besides poor engineering (which is root cause of LSPI), was further fueled by limits in zinc and phosphorous in ILSAC specifications (also been discussed numerous times).
European manufacturers haven't required or recommended API oils for a long time. If you see somewhere API, that is just to add oil in case there is some oil missing in the engine so you need to top off.
Yes, you can buy API pils in the whole world. Also, many oils approved for Euro specifications are API oils too.“API is for the Whole World.
European manufacturers have their own approval process”
Which means APi isn’t for the whole world….
The struggle is real !Yes, you can buy API pils in the whole world. Also, many oils approved for Euro specifications are API oils too.
We know you struggle with this, so it is ok.
But not for the American drivers whose cars recommend SP, but also want to benefit from the stricter Euro approvals.SP is absolutely irrelevant for European vehicles.
Still no point if going for European approvals. MB, BMW, VW approvals are far, far more stringent in all aspects. If you going for MB229.52 for example, it is absolutely irrelevant if it is API SP.But not for the American drivers whose cars recommend SP, but also want to benefit from the stricter Euro approvals.
It's obvious the inclusion of API in Euro oils is not meant for Euro cars. No need to get worked up on it.
That is correct, but to reiterate, the inclusion of SP is not to make Euro "better", but to allow it to be run in cars that require SP.Still no point if going for European approvals. MB, BMW, VW approvals are far, far more stringent in all aspects. If you going for MB229.52 for example, it is absolutely irrelevant if it is API SP.
Now, if warranty, you still have to then comply with Dexos etc.
Allow? How do you mean allow? All American vehicles now have their own approvals, so if warranty, you still must use Dexos etc. to keep it.That is correct, but to reiterate, the inclusion of SP is not to make Euro "better", but to allow it to be run in cars that require SP.
To comply with warranty - If they recommend it, of course. Many Koreans just go by API & ILSAC.Allow? How do you mean allow?
I already agreed on that.There is nothing SP has that would make that oil better.
Koreans require ILSAC, so you are kind of stuck.To comply with warranty - If they recommend it, of course. Many Koreans just go by API & ILSAC.
Here's the 2021 OMKoreans require ILSAC, so you are kind of stuck
how they gonna determine if you go C3 MB229.52 that you are not complying with warranty.
Not all C3 MB229.51/52 oils are API. Mobil1 ESP 0W30 is not. Motul too. Sure, you go SP and tgat is it. Though, best Euro oil is SLHere's the 2021 OM
If I were to own that car, I'd chose a Euro SP to comply under warranty.
They wouldn't have to - it's the latest API. The Euro approvals are a nice extra to have.
Edy,Not all C3 MB229.51/52 oils are API. Mobil1 ESP 0W30 is not. Motul too. Sure, you go SP and tgat is it. Though, best Euro oil is SL![]()
Sure, you go SP
Who said they did? I use non API oil. If oil can meet API, you certify and sell to Korean crowd that that hopes that will save the day.Edy,
In your expert opinion. Why do manufacturers change their Euro oils formulations to comply with the latest API?
Honest Q.
As long as it's Euro, yes!![]()
M1 0W-40Who said they did?
Yes they did. However, Castrol 5W40 is not Castrol's premier product. It is 0W30.M1 0W-40
Castrol Euro Car 5W-40
They said it. And they did.
Thank you.Yes they did. However, Castrol 5W40 is not Castrol's premier product. It is 0W30.
Again, some are some are not. I would say those that are not are marketing decisions.
Also, take into consideration that additive packages are stremlined. It is also strictly a logistical issue. Motul X-Clean 0W30 EFE has same additive package as Mobil1 ESP 5W30 API SP, but Motul is not API SP. WHy? I think it is because: who cares.
