2025 BMW M60i (S68 Engine) LL-01 vs LL-01 FE
LL04 won’t so well in the markets with sulfur levels above 50ppm. Even Australia still runs regular at 150ppm. There are markets with higher concentration.
BMW in general was always sloppy with oil recommendations. If latest matrix lists LL04, nothing stops people running LL01.
Understood. BMW isn't recommending LL04 on any ICE outside of EU, so LL04 shouldn't be suitable in countries like Australia.
In the case of OP, the oil matrix says LL04 is not suitable for S68. I'm guessing it is because the "technical changes in Bx8TU2" make 5W-X oils not suitable, and LL04 has 5W-X oil. LL01FE is still approved for some Bx8TU2 (and S68) because LL01FE oils are (mostly?) 0W-X and thus not affected by these "technical changes"?
Third to last sentence: "Due to technical adjustments, oils of viscosity grade SAE 5W-X are not suitable for Bx8TU2 petrol engines."
Since many LL01 oils are 5W-X, I think that's why the suitable oil matrix no longer lists LL01 as suitable for B48TU2, B58TU2, and even S68 (which was released in July 2022, around the release of Bx8TU2 series).
LL04 is the oil recommended in Australia in manuals. We just went through that discussion. You can find it on this Euro forum.
It doesn’t have anything to do with 5X or 0X. There are LL01FE oils that are 5W30.
It is about HTHS and they want lower HTHS bcs. CAFE and WLTP.
However, Australia in this case doesn’t have WLTP, so nothing stops BMW from using oils with HTHS 3.5 and higher.
I read that discussion before. That car has B58TU0, which is suitable for LL04 in many markets. But like you mentioned earlier, Australia has high sulfur levels, so I'm not sure why BMW was recommending LL04 for gasoline engines in Australia :ROFLMAO:
BTW, I just checked, LL01FE oils don't have 5W30. Liqui Moly Special Tec B FE 5W-30 doesn't actually have LL01FE approval.
Motul still has 5W30.
BMW 2018-2022 approvals were excluding 0WXX oils. 2022 update does not exclude winter rating. In 2022 update many 0WXX oils regained LL01 and LL04.
Nothing to do with that.
No one can access your links.
Yeah, BMW hasn't been recommending LL01 due to CAFE, and hence, LL01 isn't highlighted in blue for Bxx engines. But up until BxxTU1, LL01 is still technically suitable as long as they aren't fitted with a GPF.
With the intro of BxxTU2 (B48TU2, B58TU2, S68, etc.), BMW doc says LL01 is no longer technically suitable. I guess either they just don't want to bother validating LL01 on these newer engines, or there is something about these engines that makes LL01 no longer suitable.
You should take a look at the differences between LL04 and LL19fe. LL04 and LL19fe are identical except there's a fuel efficiency component to the approval. Same min hths of 3.5cP.
Good point. See below BMW tech doc about 5W oils on Bx8TU2 engines
Since LL19FE (and LL01FE) oils are 0W-X, I think that's why they are listed as suitable for Bx8TU2 and S68. Some LL01 and LL04 oils are 5W-X, and I guess that's why they are not listed as suitable.
if bmw wanted to tell the truth they should mention these tech adjustments.bcs. there arent any ,its all about CAFE, they use the ''tech'' word ,so to be scared and stop using what they dont want,ll04-ll01 oils. if they tell its all about CAFE but you can use ll01 oils then nobody will use fe oils,at least these who read about oils.
That makes zero sense. You can buy 0w-X in LL04 or LL01. Besides, there's a negligible difference between 0w30 and 5w30 in all but the coldest temps.
BMW is blowing smoke up their customers rear ends.
We don't have to agree with BMW, and it could be nonsensical, but those engines are not approved for full fat LL-01 or LL-04 either. It is at least logically consistent in that every oil specification approved for those engines is exclusively available in 0W grades. Almost all variants of TU2 have dropped LL-01 and LL-04 checkmarks in TIS and some of them don't even allow LL01FE or LL12FE.
Most likely it is because they are terrified of regulatory action to use the correct term rather than "technical".
Yes, it's... technical. Sort of.
Possibly, but I'm not aware of what legal framework would distinguish 0W vs 5W oils within their own spec and if even EPA/CAFE would care so much about the oils recommended in an internal database vs factory fill, manual recommendation, and dealer fill. Those engines without the LL01FE/LL12FE checkmarks are the first using eVanos. I know we assume these are not engineering decisions because 99% of the time they aren't, but this one feels a bit more specific.
CAFE (or more precisely the EPA) as well as the EU and British regulations don’t really care about the winter rating per se, what they do care about is strict compliance with whichever oil grade was used fuel economy or carbon emission testing. Winter rating is included in this. They cannot deviate from that.
Aren't they approved for LL19fe which is essentially identical to LL04 in terms of HTHS but there's some trick FE component to the approval.
Why is it different now than in 2022 though? They are happy to allow the thicker LL19FE oil for the new V8 also. I don’t see any evidence of a worldwide regulatory crackdown.
There could be a variety of reasons. I guess I've given up on increasingly goofy oil recommendations by some manufacturers, regardless of what they are. For me I go by what I know about SAPS level, HT/HS and an appropriate winter rating. Manufacturer recommendations are so clogged up with regulatory requirements that I think they have lost sight of what's best for the engine.
But that's just me. If someone doesn't feel comfortable doing that then I'd default what the book says.
