Motor Oil - Boron Additive Formulation
Texas
I've noticed that ~2008 that some formula changes took place (Pennzoil conventional, Motorcraft/ VOA's & used oil analysis) where the content of Boron went from 0 to ~100+ppm. I've read in other papers that it forms a permanent layer that is 85% the hardness of diamond on metal surfaces of the engine, then layers of the Boron (like graphite) slide over each other, creating an almost frictionless interaction (coefficient of friction lower than Teflon). Seems this is a component to want to have in an additive package.
http://www.anl.gov/Media_Center/News/2007/ES070803.pdf
Originally Posted By: rudolphna
I thought that was Moly...I thought moly was anti-friction, and boron was anti-foaming and a detergent.
Boron is also a boundary lube/anti-wear additive.
