wemay
Site Donor 2023
Originally Posted By: MolaKule
Originally Posted By: HKPolice
I don't think the difference matters all that much. Blackstone's blog even said that out of all of UOAs they've done, they found no significant difference between dino & synth when oil is changed at recommended intervals and the engine was in good mechanical shape to begin with.
Even page 5 of this PDF states that only 5-10% of engine lubrication is boundary layer which is what the test is for. This is also why dozens of UOA with moly additives or high moly oil shows no difference in wear numbers.
About this new additive:
The fuel econ savings of this additive is due to the lower viscosity oil used in the test (page 11, 5.38 cST vs M1 5w30 @ 11.38 cST). If this additive was put in regular 5w30 oil with the same cST as M1 then I doubt we'll see any significant increase in fuel econ. IMO it should've been tested against 0w20 but then the result will probably be under 1% and therefore wouldn't attract as much funding.
This additive does have a lot of potential when used with future super low viscosity oils but considering how most Americans love thick oil....
My thoughts as well.
Agreed. Blackstone and other companies that perform UOA provide the best 'test' results for real-world usage. Interesting read though, thanks for sharing.
