http://energy.gov/sites/prod/files/2014/07/f17/ft014_qu_2014_o.pdf, on page 12, "Rolling-sliding bench tests on MTM2 at GM". Forget the IL stuff in there for now, although its cool and has been discussed on these forums a bit.
That is the first time I've seen a comparison between a conventional and synthetic for wear rates. Assuming that Lubrizol, Oak Ridge, and GM engineers know how to run a proper wear rate test, this is startling to me. (The condition is Boundary Lubrication (BL), not the conditions where an oil film separates the parts. When there is an oil film (EHL), no wear occurs, note Stribeck Curve.)
Questions:
1. Is this typical? This is Mobil Conventional vs. Mobil 1.
2. Additive packages between these two oils looks similar. Actually the conventional has more moly, so it should "win"! Mobil 1 has a bit of boron, which helps. Those are the major differences in additive packages that show up on PQIA's and BITOG's VOA lists anyway. So, obvious question becomes: Does Group III Mobil 1 basestocks account for the drastic reduction in Boundary Layer (BL) wear rates?
3. Or is it Mobil1's component they use to put on the bottles called "Supersyn"?
4. Anybody know of any more solid quantifiable looks at a comparison between the wear rates of synth vs. conventional oils? I've seen that Mobil 1 scores an 18 nm (out of max 90 nm), as does Castrol GTX Synblend (now Magnatec), on the Sequence IVA, as published in marketing bar charts, but that really doesn't cover much comparison ground.
Questions:
