Originally Posted By: A_Harman
Originally Posted By: Shannow
Crawfish Tails,
great find, and thanks for posting.
Interested that the (dino) ASTM reference 20W30 is no additive, no VII...makes the new 15W30 no VII diesel oils look more realistic.
I like the fact that they acknowledge the move to thinner oils provides wear challenges to overcome...
But the Ionic Liquid really does seem to answer the shortcomings.
I think it's kind of self-serving that they used a 20w30 as the reference oil. Who uses that anyway? Talk about fighting a straw man. But I'm digressing.
What I really was intrigued with was the Ionic Liquid. The wear graph on page 13 of the DOE report shows comparable Iron content, but the Aluminum content for the thin IL oil is 3X as much as for the M1. Coming out of an LSX (or any GM LS engine), that means bearing wear. All the bearings in that engine, be they main, rod, or cam bearing are Aluminum-lined. Maybe the thin IL oil is better at protecting liners than it is bearings?
I think so based on the study, the old saying " thicker protects bearing and thinner protects rings and valve trains" is true?
I will say there was no ring groove and the cross hatching was still visible on my 04 below when the oil pump bypass stuck open took out the engine at 250+k miles. The engine always had a xw30 in it.
