Mobil 1 ESP 0w30 observations
Switching the Valvoline Restore and Protect topic slightly - I believe a max OCI using Valvoline Restore and Protect and a good oil filter is important . Run an OCI too long using Valvoline Restore and Protect and you will introduce deposits which you have been trying to clean . Unless all driving is interstate / highway driving - I suggest to keep Valvoline Restore and Protect OCI’s at between 3,000 to 4,000 miles … This is not an oil you want to play long drain games with .
I’m running 5k with no problems with Valvoline Restore and Protect.
Agree completely. On my first OCI of Valvoline Restore and Protect it was clear that the rate of cleaning was falling off pretty rapidly. As one would expect of a cleaning effect ostensibly attributable to a consumable additive. Of course one would expect the rate of cleaning to slow as the main agent gets used up and its concentration diminishes.
It wasn't as clear to me in the first OCI that the cleaning was slowing a good deal until I saw the massive increase in cleaning rate on the second OCI.
All that to say-- I completely agree with Valvoline Restore and Protect is a standard or shortened OCI oil. IMHO it is NOT an extended OCI oil and it would be unwise to try unless you have worked up to it and you have an already very clean engine. If you have a very dirty or heavily varnished engine like my old Odyssey does, It's probably best to short OCI and work back up to whatever "normal" you use.
I'll change this 2nd Valvoline Restore and Protect OCI when the OLM hits about 50%. That should be around 3k miles.
GTL/PAO/Ester blend
i read Mobil 1 ESP 0w30 msds and i see very little of esters almost 1%, almost 10% PAO and a big amount of GTL.
https://seattleautomotive.com/files/SDS/MOBIL 1 ESP 0W-30_124547.pdf
1-DECENE, TETRAMER AND TRIMER HYDROGENATED 68649-12-7 5 - < 10% that is PAO
PHOSPHORODITHIOIC ACID, MIXED 0,0 BIS (1,3- 84605-29-8 0.1 - < 1% that is esters
DISTILLATES, HEAVY, C18-50 - BRANCHED, CYCLIC 848301-69-9 848301-69-9 30 - < 40%, that is GTL
i expected more PAO/ester analogy? for a pao/ester called oil.it seems it is more a gtl oil
Why are we looking at a 2022 SDS that's not hosted by XOM? Also, that ester you highlight is ZDDP. Most esters don't get called out on SDS sheets, which is also part of the reason why the numbers listed there do not add up to 100%.
Current SDS which is 2 years newer, August of 2024.
Relevant section:
25-50% GTL
10% PAO
11% "other" base oils
ZDDP isn't called out on this SDS.
I've been running this oil for a week now in my 04 Silverado with the 5.3 Vortec, and here's my completely unscientific findings:
Starts faster
Engine seems to warm up quicker
Incredibly smooth and responsive acceleration
I don't track fuel economy so I have nothing to share there. So far quite pleased with this oil selection and I think I made the right choice with the switch. With the kv100 viscosity being nearly light 40 grade territory, it isn't much lighter than the Swepco 306 15w40(12.7 kv100 per voa) it replaced. Much lower zddp than the Swepco but higher boron and Moly, much lower calcium than the Swepco but with the possibility of some ester content in the ESP the detergentcy and seal conditioning aspects should be better long term. Just thought I'd share.
Happy Valentine's Day fellas!
Isn't the old champ of PCMO's, Mobil 1 0W-40 still the higher performance oil, with 0W-30 ESP being the more compliance based?
I'm talking merely from an engine protection standpoint as opposed to emissions system protection? I own and prefer older cars and engines so don't really need a low SAPS oil🤔
We believe the Mobil 1 ESP 0w30 to have some cleaning ability - but how would you rate the wear protection in its class ?
I´m sure some interesting responses will come to that question, but honestly, wouldn´t you have to drive an engine nearly exclusively using that oil until it wears out to get the real answer?
about the same as any off the shelf oil in the 0w/5 range, boutique oils can offer a bit more protection (HPL,AMSOIL Signature Series etc) and longer change intervals. Depends also on the vehicle condition, driving habits, climate (fuel dilution ) etc, certain 5w-30 oils can actually have better cold performance and running viscosity to note per CCS and MRV test results if obtainable from the manufacture/blender. use the oil in question (esp) for what it is formulated for, ( euro) . many other oils use small to moderate levels of G. 4&5 base oils in the blend they market.
How do the boutique oils offer a bit more protection? How is that measured?
