One of the mysteries surrounding high-mileage oils is whether they are any different than vanilla oils or they are a marketing gimmick. In fact, the Super Tech PDSs tell us that the Super Tech High-Mileage is identical to the vanilla Super Tech; therefore, in that case the only difference is the labels on the bottles.
However, this doesn't seem to be always the case and some high-mileage oils could be radically different than vanilla oils.
We already knew from Fourier-transform infrared (FTIR) spectroscopy that all Mobil 1 oils except the Euro (FS and ESP) flavors contained the API Group V AN base stocks (Synessticâ„¢) and the Euro (FS and ESP) flavors contained the API Group V POE base stocks (Esterexâ„¢). The amount of POE base stocks in the Euro (FS and ESP) flavors is thought to be around 5 - 7% (35% FTIR oxidation). However, the amount of AN base stocks is unknown. POE is also a very expensive base stock, more expensive than the already expensive PAO. AN is likely cheaper.
I updated my base-oil viscosity and viscosity-index improver (VII) calculator to calculate the base-oil viscosity index (BO VI) along with the base-oil KV40 and base-oil KV100 (BO KV40 and BO KV100).
While the calculated base-oil viscosity index (BO VI) for most oils is within the range one would expect from the marketed, MSDS-specified, or speculated base-oil compositions of the oils, I discovered an anomaly in Mobil 1 High-Mileage (M1 HM) oils, with the base-oil viscosity index (BO VI) coming out of the calculator much lower than one would naïvely expect.
Now, the calculator assumes olefin copolymer (OCP) VII because other VII types have a hard time passing the turbocharger-deposit tests, and the base-oil viscosity index (BO VI) calculated for most oils are just one would expect. Exxon Mobil seems to use OCP VII in their oils, the so-called Infineum viscosity modifier (VM). It's possible that they chose to use a different type of VII for the M1 HM oils, which could explain the anomaly. Nevertheless, I doubt this is the case.
A possible explanation of this M1 HM anomaly is that the M1 HM base oils contain a very high amount of alkylated naphthalene (AN) base stocks. 4.7 cST AN base stock (Synessticâ„¢ 5) has VI = 74 and 12.4 cSt AN base stock (Synessticâ„¢ 12) has VI = 105. These would lower the base-oil viscosity index (BO VI) substantially. As I said before, we already knew that all Mobil 1 oils except the Euro (FS and ESP) flavors contained AN base stocks and the Euro (FS and ESP) flavors contained POE base stocks. The results of the calculator are suggesting that the amount of the AN base stocks in the M1 HM oils are much higher than in other M1 oils.
In fact, the AN base stocks are used as seal swellers and engine-deposit cleaners, which are therefore very suitable for high-mileage oils:
Information by TRiiSO on Exxon Mobil Synesstic AN base stocks
It would be very interesting if the Mobil 1 High-Mileage oils are indeed made of the Synessticâ„¢ Group V alkylated naphthalene (AN) base stocks.
The full discussion and the latest base-oil viscosity and viscosity-index improver (VII) table is here:
Latest base-oil viscosity and viscosity-index improver (VII) table
