Originally Posted By: 147_Grain
Suggest you run a 0W-30 in the winter and 0W-40 in the summer for this high-revving engine.
Personally, I like the blend of 0W-20 / 0W-40 year around and would use the Widman Calculator to thicken or lighten up the oil (a little) using HTHS ratios as the #1 value.
That was exactly my thoughts. Using the calculator, with the 60/40 mix, the 100 degC viscosity is ~0.3 to 1.0 cSt more than the regular M1 30s and ~0.6 to 0.8 cSt less than the M1 high mileage 30s.
BTW, I put the S2000 into storage during the winter.
Originally Posted By: A_Harman
60% of 3.8 HTHS + 40% of 2.7 HTHS will give a final HTHS of about 3.3 or 3.4, so I think you're in a good space to keep the final sheared HTHS above 2.9. If you're car has been running fine on M1 0w30, it should continue to do fine on the 0w40/0w20 blend.
Other oils I would consider would be M1 HM 10w30 or GC 0w30, but I realize this defeats your idea of only keeping two types of oil in the house.
Thanks.
I've thought about these other oils, but am looking for convenience. Also, my S2000 somehow doesn't consume any oil, so I didn't feel the need to use a high mileage oil with greater cold start viscosities. This is my first performance oriented Honda that doesn't regularly consume oil. Lastly, finding GC is a pain.
