Originally Posted By: TrevorS
If a 5w40 is only required for cold temp, then the relevant minimum HTHSV interpretation is for the SAE 10w30 grade.
Yes, MINIMUM HTHS, note there is no maximum. Perhaps the engine operates properly with an HTHS between 3.0 and 4.0? We don't know, because Honda doesn't provide a spec, all they provide are two oil recommendations.
Quote:
As I said, they will range from 2.9 to 3.3. Easy to find a 10w30 with HTHSV less than 3.5 right?
Yes, and those oils will be conventional. Honda doesn't spec a synthetic, nor did they create a specific oil requirement (like they did with HTO-06) for this car. They obviously observed that a conventional 10w-30 was stable enough to meet the minimum requirements of the car.
That said, the 5w-40 recommendation implies a synthetic. It is also recommended for all temperatures. Honda obviously factored in shear to that recommendation. And as I said, they would know that the 5w-40 would shear, whilst still exceeding the minimum necessary HTHS requirements of the engine.
Quote:
So 3.8 is quite a bit thicker than necessary.
Thicker than the minimum allowed maybe. Not sure why you assume this is such a bad thing. Oil temperatures have a major effect on viscosity, so even with the 10w-30 in the pan, the HS visc observed by the engine with cooler oil temperatures is going to be greater than necessary.
.6-.8cP isn't much in the context as to how much temperature has a role on visc.
Quote:
Bringing up HTHSv for 5w40 is just confusing the issue.
Ummm, you brought it up
Min HTHSV of a 5w40 oil is 2.9.
M1 0w40 has a HTHSV way above that.
In the US, any oil marked Euro typically has an HTHSV above 3.5 including Euro oils in the SAE xw30 grade.
This will be heavier than both the 10w30 and 5w40 oils that Honda allows by a good margin.
Quote:
Clearly the objective there was to provide 5w performance. Yes they may have felt a 5w30 would not be shear stable in which case it just reaffirms they wanted to stay above the 2.9 minimum.
That's what I said. Which means that they were not concerned with the HTHS of the 5w-40 being higher than the 10w-30. They wanted 5w-xx performance and wanted to ensure that the oil exceeded the minimum HTHS requirements of the engine.
