cheesepuffs2
- Joined
- Jun 3, 2021
- Messages
- 1,624
I agree and I get why people are saying this, but I'm not interested in buying yet another jug of oil.0w30 ?
Somewhat like the guy at Project Farm ...There is a difference at -20 but it is not a huge one. As you get 10 degrees colder the difference is more prevalent. We look at multiple beakers side by side in a lab freezer.
I went 7.5k on Pennzoil Platinum Euro 0w40 and the used oil analysis was great on viscosity & TBN, it’s here on the board somewhereWhat OCIs did you do with yours?
I wonder how low a temp one could run a 0w-40 mixed with HPL Engine Cleaner 30?
Pennzoil beats Amsoil in cold flow so I’d almost say use the Penn over Supertech. SP is an ok oil but their cold flow loses to either of the two. Unless you’re in -40 degrees I’d add a block heater regardless.I have two jugs in my stash right now.
One SuperTech 0W-20 HM, and one Pennzoil Platinum 5w30 HM.
Engine is a Honda 3.5 V6. Burns a bit of oil, maybe 6/10ths of a quart every 3,000 miles. Car calls for 5W-20.
Mileage is approaching 150,000. I'd like to start running 30 weights for film strength, but with the cold weather almost here (coldest mornings for me are about -10 degrees F. Not crazy cold, but still cold).
That said, I don't want to run the 5w30 weight in the winter if it's going to induce extra wear as cold start-up over the 0W-20. At those temps though, is there even really a difference in pumpability, or does that really only matter once you start getting to more like -40 degrees with synthetics?
You referring to API SP oil? If so, what's the API designation have to do with the cold starting performance? ... that's what the SAE J300 "W" rating (CCS and MRV viscosity test) is all about.SP is an ok oil but their cold flow loses to either of the two.
Cold flow has little relevance to ICE starting. It’s about temperature and shear induced gelling near the pickup tube. After that it flows.Pennzoil beats Amsoil in cold flow so I’d almost say use the Penn over Supertech. SP is an ok oil but their cold flow loses to either of the two. Unless you’re in -40 degrees I’d add a block heater regardless.
Per SAE J300, a "5W" rated oil is good to -30C (-22F) ... so you're expected -10F it's still well above the limit. A 10W in J300 has a minimum temperature of -25C (-13F). Those are the absolute minimum temperatures they should be used at. Most car manufacturers will back off some from those minimums, but that's what it is per J300.Mileage is approaching 150,000. I'd like to start running 30 weights for film strength, but with the cold weather almost here (coldest mornings for me are about -10 degrees F. Not crazy cold, but still cold).
Does thicker oil not offer more protection from the MOFT going to zero in the first place?Per SAE J300, a "5W" rated oil is good to -30C (-22F) ... so you're expected -10F it's still well above the limit. A 10W in J300 has a minimum temperature of -25C (-13F). Those are the absolute minimum temperatures they should be used at. Most car manufacturers will back off some from those minimums, but that's what it is per J300.
BTW, "film strength" has nothing to do with the viscosity. It has to do with the wear protective tribofilm layer on parts from the AF/AW additives in the oil when the MOFT (the film thickness) goes to zero.
All cold oil will give good MOFT, because MOFT is directly related to the viscosity.Does thicker oil not offer more protection from the MOFT going to zero in the first place?
Is improved MOFT at high temps via increased viscosity not a thing though?All cold oil will give good MOFT, because MOFT is directly related to the viscosity.
Of course ... that's why some here opt to go a grade higher than recommended. To add some MOFT headroom for some extra wear protection. MOFT is the only thing that keeps moving parts from rubbing and wearing on each other. The "film strength" is what the protective tribofilm from the AF/AW additives, and that takes over to help reduce wear when the MOFT goes to zero and parts start grinding on each other. I'd rather rely more on film thickness (MOFT) instead of the last defense against wear of the film strength.Is improved MOFT at high temps via increased viscosity not a thing though?
I appreciate the info. I think maybe my point wasn't clear enough because I'm not concerned about MOFT when cold/upon startup. What I'm getting at is essentially "I want to run thicker oil but I want to know that the higher W number of that thicker oil (0W-20 vs 5w30) isn't going to cause more wear at cold startup that would negate the added hot protection".Of course ... that's why some here opt to go a grade higher than recommended. To add some MOFT headroom for some extra wear protection. MOFT is the only thing that keeps moving parts from rubbing and wearing on each other. The "film strength" is what the protective tribofilm from the AF/AW additives, and that takes over to help reduce wear when the MOFT goes to zero and parts start grinding on each other. I'd rather rely more on film thickness (MOFT) instead of the last defense against wear of the film strength.
Don't worry about MOFT with the "W" rating ... only that you use the correct "W" rating for the cold start-up conditions so the engine can start and adequately pump the oil through the oiling system.
Like mentioned, use a "W" rating that's appropriate for the coldest start-up conditions. I gave info based on J300 in post #51, which says 5W would be usable down to -22F. If -10F is the coldest you expect, then 5W should be fine. But if you're afraid it's not, then use a 0W and sleep well.I appreciate the info. I think maybe my point wasn't clear enough because I'm not concerned about MOFT when cold/upon startup. What I'm getting at is essentially "I want to run thicker oil but I want to know that the higher W number of that thicker oil (0W-20 vs 5w30) isn't going to cause more wear at cold startup that would negate the added hot protection".
And it failed so did Amsoil Pennzoil beat them both.You referring to API SP oil? If so, what's the API designation have to do with the cold starting performance? ... that's what the SAE J300 "W" rating (CCS and MRV viscosity test) is all about.
What failed?And it failed so did Amsoil Pennzoil beat them both.![]()
I run the 10W30 QS FS in the last months of winter the previous year. Ran fine cold. But only a few 15degF warmups. Not particularly relevant, but the PP of this oil was listed on the PDS as -54deg F. I used it in my snow blower and that engine loved it - so I tried it in the Ford. A known and recorded fuel diluting D.I engine. If @ChrisD46 installs the Quaker State 10w30 there is certainly NO NEED to mix with the handicapped 5W30, The 10W30 formulation is a special performer in my long, storied experience. I say avoid VM like plague in D.I. engines. - KenI would venture to guess that a 10W30 mixed with 5W30 isn’t any worse at start up than a 10W30, and the poster is in Georgia, so, it would be fine for him.
