Originally Posted By: Kuato
Thanks for the clarification. While many would be fine changing it by the calendar, OP is concerned about draining perfectly good oil. He has his reasons and I respect them, whatever they are.
That's why I answered as I did; the ONLY way to be certain about the condition of your engine oil is to have a used oil analysis performed. Color, oil dot test, smell, and any other such method cannot tell you how much active additive remains nor can those methods tell you the TAN or any other important characteristics of the oil in your sump. Calendar time in the sump only tells you calendar time in the sump; there are too many variables in play.
There are people on here that have done used oil analysis with more than 3 years on the oil, in an infrequently driven vehicle, and their oil was in good condition.
You're saying it makes sense to spend the money to change the oil if in doubt....I'm saying that a used oil analysis will remove doubt. I'm not saying that OP should use his oil until the very last possible bit of additive is used up. Correct me if I'm wrong, but it seems that just like many on here, he is striving for an interval that he is comfortable with that also gets good usage of his oil.
I am with you on respecting whatever it is others wish to do regarding oil changes. That is why I stopped buying used cars decades ago.
As I already noted, I prefer spending "used oil analysis Money" on oil and filter changes. I never speculate on oil condition. I change it at the manufacturers recommended intervals, or as indicated on the oil life monitor or more frequently than required (usually every 6 months or 5,000 miles whichever comes first). I only use oils specified by the manufacturer and OEM filters. I believe that this approach eliminates any need for used oil analysis.
There was a serious classic car collector on another car forum I used to frequent. He said that on several occasions he ran used oil analysis on the engine oil on "barn finds" that had been sitting for over 25 years. Oil checked out OK. He, off course, was smart enough not to use the oil. That pretty much sums up my opinion of the value of used oil analysis for most situations. I can, however, see the value in high volume commercial fleet applications.
