This gear oil replaces Lubrication Engineers LE 607 Almasol (SAE 90) with the new Duolec EP/AW/tackifier additive and a synthetic blend (LE 607 was 100% conventional oil with Almasol EP/AW additive) base oil. I really liked how 607 performed and was worried when they changed the formula. It looks like it will be OK though.
Vehicle-2004 Honda S2000 (AP2)
Miles-46,442
Miles on diff (Torsen LSD)-46,442
Miles on oil-6,000
Diff oil capacity-0.82 qts
Previous two used oil analysis were LE 607. This sample was the first UOA and fill of 1605.
Miles on oil/6000/11,415/8000
Miles on unit/46,442/26,250/14,835
Aluminum/0/2/1
Chromium/1/1/2
Iron/79/172/188
Copper/0/0/1
Lead/0/0/0
Tin/0/0/0
Moly/0/0/0
Nickel/9/17/20
Manganese/1/4/0
Silver/0/0/0
Titanium/1/0/0
Potassium/1/1/6
Boron/44/12/32
Silicon/10/41/36
Sodium/2/2/1
Calcium/9/6/14
Magnesium/5/13/8
Phosphorus/1190/1591/1481
Zinc/11/14/11
Barium/1/0/2
SUS Viscosity@210F/97.2/93.4/89.4
cSt Viscosity@100C/19.69/18.79/17.83
Flashpoint F/425/425/425
Water%/0.0/0.0/0.0
Insolubles%/0.2/0.3/0.5
The drain plug had a very small amount of gray paste on it (magnet). The smallest amount I've ever seen on a drain plug. This fill had a small amount of residual LE 607, since I didn't flush the diff. I expect the viscosity will be a little higher if I do another UOA. I change the gear oil frequently (whenever the transmission fluid needs changed). It only has a 0.82qt capacity, so I figure it's good insurance.
Miles-46,442
Miles on oil-6,000
Aluminum/0/2/1
Chromium/1/1/2
Iron/79/172/188
Copper/0/0/1
Lead/0/0/0
Tin/0/0/0
Moly/0/0/0
Nickel/9/17/20
Manganese/1/4/0
Silver/0/0/0
Titanium/1/0/0
Potassium/1/1/6
Boron/44/12/32
Silicon/10/41/36
Sodium/2/2/1
Calcium/9/6/14
Magnesium/5/13/8
Zinc/11/14/11
Barium/1/0/2
Water%/0.0/0.0/0.0
