Originally Posted By: skyship
Originally Posted By: RiceCake
Whats funny is improvement or not, what you're seeing is absolutely of zero concern to the operation of the engine or anything else.
Very true, I can't see any sludge just a little light varnish that is normal for older engines. That varnish will be helping the oil seals and gaskets to function, it should be left in peace.
If you own a late model Toyota your both wrong. Any deposits matter including the precursor to sludge, varnish. Toyotas have narrow oil passages in 2 key areas. One is the vvt-i system, the other piston oil return holes. If enough varnish gets into the tiny passages of the vvt-i, a host of operational issues will be experienced as the controller hangs or gets stuck in the wrong phase. If enough varnish gets into the piston oil return holes it can flash and harden into carbonized mass. Thats a bad thing. Will burn oil like a Saturn because the oil scrapings cant return to the sump. Usually a teardown is required to clear the holes with a drill. Primary reason why so many Toyotas burn oil is clogged piston oil returns, nothing else is usually wrong. Clogged with carbon deposits whether sludge or varnish. Can't generalize like that. It does matter to some engines.
