- Joined
- Oct 3, 2023
- Messages
- 896
This is the first run on @High Performance Lubricants PCMO oil after the engine cleaner 30 run from the last drain. The filter looks more visibly loaded than the last filter. You can see there is a lot more carbon chunks at the bottom of the can and the magnets caught some stuff as well as surprised its quite very little despite the hard spirited driving. You can see the comparison to the dried last pulled filter from the which I have failed to remove end caps on despite manhandling it twice with gloves and vise grip pliers.
Donaldson P551132 went back in and topped off with the same oil and will re-sample again at 10k. So far the dip stick blot test shows the oil is still clean with the same light yellow stain as before seen in the last drain. Wrapped up the media with shop towels and will update later this weekend when the media is dry. Might take a week or two get oil analysis results. the HPL oil sample kit is processed by WearCheck based on the QR code scan.
Previous oil filter thread: https://bobistheoilguy.com/forums/threads/fram-fs3600-a02521-about-2338-miles-with-hpl-ec30.378041/
FRAM Titanium FS3600 - 5603 Miles HPL PC5W30-Q
- Mewbs
- 49
- 1
First HPL oil run, oil was sampled from the filter but was not drained.
Pink wired backed 2...
