11,000 mile Fram FE10575 C&P
NY state
11,000 mile filter off a buddies 18,000 mile oci.
Out/off: HPL passenger car engine oil 5w30 4.5 quarts, Fram endurance FE10575
In/on: HPL passenger car engine oil 5w30 6 quarts, Fram Endurance FE10575
This is the second Fram endurance FE10575 off this truck during this 18,000 oci. First filter changed 7,000 miles.
I believe the filter held up well and is loaded up. It has some weight to it and took quite a while for the free oil to drain out of the can for a picture.
I will wick dry and update post once wicked. Owner may provide the UOA when it is run. I will post that if possible as well.
Can you measure the media stack height from endcap to endcap with a ruler / tape measure?
Am I understanding this correctly? Basically he runs 18k mile OCI but changes the filter during the run? If so, why if the filter is rated for 20k miles or so?
First run with HPL. Anticipating engine cleaning and not trying to over load the filter. After wicking this filter will determine if he will go full oci length on filter in the future.
Will be interesting to dissect this filter to get answers. As @bullwinkle questioned it doesn't look like wire backing. Are you sure it was an FE & not an Ultra? Could Fram not be offering wire backing on some of their Endurance models. :unsure:
We'll see what it looks like dried up...
100% sure its labeled an endurance. Looking forward to dissecting in a few days
Nice pictures and cut and post. I Thank You
