Kreen cleaning sneak peek - 1st dose - 800 miles
Originally Posted By: Artem
Originally Posted By: MBS500
I don't remember what it said on the bottle when I had it, but I don't think it said: cleans varnish. I don't think it is an easy job for any cleaner.
No it doesn't. It doesn't mention sludge or anything else for that matter. It says that it's an engine cleaner. As an engine cleaner, I expect it to KREEN! Simple as that. I don't understand why people keep acting like it's ok that an engine cleaner DOES NOT CLEAN A THINK! I don't get it.
It served me well in 1mz-fe I had. Piston soak made a miracle,it stopped drinking oil like crazy (1q in 300 miles up to 3000-4000 after soak),sure it cleaned some sludge too,but looking thru filler hole ( I cut out baffle),most varnish, not ever varnish, more like stains in metal pores(looks same as yours)had maybe a little improvement. I ran 1 can in total.
Btw if you remove cover again, clean Ventilation passages,just in case, blow brake/carb cleaner thru the hole(s).
