I didn't assume anything ... I read what you posted. What you posted previously does not show you fully understand an engine oiling system fed by a PD pump. Nothing you can say will change the words you already posted.
I asked for the data, because without it you're just assuming that's true in all situations. What about the wear test data of a 0W-20 vs a 5W-20 at high shear conditions in the engine? Assuming the KV100 is exactly the same between the two.
Let's hear about these "boundary conditions" inside of an engine. Most here know the 3 different realms of lubrication.
Saying 0W-20 is better than 5W-20 can not be concluded without some proof. Like I said, at -30C it might be, but any time you are above the min W rating temperature of 5W I highly doubt you will see the difference ... unless you have the test data to prove it.
Any time you’re hitting that rating you’ve already failed. I posted an article previously on that.
Secondly, decreasing viscosity can decrease friction which leads to less wear. Here is a study on it - warning, PDF.
https://www.stle.org/images/pdf/STL...cts of Lubricants on Piston Ring Friction.pdf
Given, this is with piston rings. But you can take the same ideas to other areas.
Given, formulation differences, a Xw20 should be the same (approximate) viscosity at 212f. You will have less wear using a lower viscosity oil during the cold start phase.
