It turns out that TEOST 33C test is useless for judging turbocharger protection.
Antioxidant is the key, along with the VII (or the lack of it) and dispersant.
Moly has no effect.
However, I think TEOST 33C may be better correlated with intake-valve deposits (IVD) in turbo gasoline direct-injection (TGDI) engines. Currently VW 504.00 is the only spec that tests for IVD.
Engine Oil Components Effects on Tu...Gasoline Turbocharger Deposit Protection
CONCLUSIONS
The following conclusions can be made:
1. Based on previous [2] and current findings, dispersants, antioxidants, and viscosity modifier have an effect on GMTC test response. Any impact from molybdenum level on GMTC test response appears to be minimal.
2. No correlation between the GMTC test response, measured as the percent increase in TCO temperature or average turbocharger deposit merit rating, and total deposits measured in TEOST 33C was observed.
3. Passing and failing TEOST 33C oils resulted in no significant difference in engine sludge and turbocharger deposit ratings in gasoline turbocharged vehicles under field driving conditions.
Moly has no effect.
CONCLUSIONS
