Kia K5 GT oil suggestions
Yes and you know what that means, right? Especially in light of the earlier statement "however, higher viscosity engine oils are required for satisfactory lubrication in hot weather".
No engine is damaged by any SAE grade higher than what is allowed, unless the winter rating is so inappropriate for the starting conditions that it cannot be pumped. Oils that are too thin at operating temperature can cause damage but no SAE grade is too thick.
And as far as the API certification, that is a minimum requirement.
I live in N FL. No such thing as too thick at start here unless it's some severely oxidized used oil
I live in North Carolina. It's hot here as well.
Red Line Oil 5w30 is a very good oil for turbo applications. If money is no object, go for it. Noack is a solid 6% and HTHS is 3.7. The cSt is in the same range as most 0W-40 oils. And LSPI (not that it matters in your case) isn't an issue with this oil.
Some oils worth looking at:
Mobil 1 ESP 0W-30, Mobil 1 ESP 5w30 (very nice HTHS) and Mobil 1 ESP X2 0W-40.
That Mobil 1 ESP 5w30 should be right up your alley. I mean it's used in Turbo Charged Porsche vehicles with Direct Injection.
If you want something easily available, go to Castrol EDGE 0W-40. It's got some certifications that your average 10w30, like Porsche A40. This oil is used in Turbo Charged Direct Injection engines as well.
Get yourself a Craftsman torque wrench (20-100 ft-lb) and a Husky inch-lb torque wrench as well. The filter housing is torqued to 20 ft-lb. Any less than that and you get an oil leak. Any more and you crack it. The little plastic bolt is torqued to 5 ft-lb. Get yourself a Votex drain plug from here. I would order two because the threads don't always match perfectly. Or stick with the stock plug, your choice. I like them, they remove iron particles from oil. You can find them here: https://www.amazon.com/gp/product/B07SMPN7B3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The drain plug is torqued to 32 ft-lb. Don't go over that. Test your torque wrench on something to make sure they click before you work on your car with them.
I took a look at the datasheets for Mobil 1 ESP 5w30. It does look like a good oil. You're probably gonna want to bonk me on the head, but I don't see that it's that different from the Mobil 1 High Mileage 10w30.
Both are HTHS of 3.5. the 5w30 has 11.8 cst at 100C and the 10w30 has 12 cst at 100C.
So to get the 5w they probably went with more PAO as the base and added VI to get the HTHS and viscosity.
The 10w you say is basically Group III oil with a dash of VI. The additive pack numbers look very similar.
Your opinion is that 10w is too thick at start and will somehow harm the engine? Or is your concern just about power losses? At temp those two oils will perform identically, though I suspect that the 10w with less VI will be more resistant to shearing down over time, but that's pure speculation.
I live in FL and the coldest I've seen it get here in the past few years has been low 20s. Not a problem for a 10w. I'm sure the 5w would spin a little faster when you hit the button but as long as it cranks I'm happy.
So what does 5w30 do besides crank faster?
I like everything about the red line oil except the pricing...
M1 is on rebate right now.
Your Turbo bearings need oil as fast as possible when you start the engine. Thicker oil won't help. I'm not sure that there is a good reason to use 10w30 for anything these days. My top pick goes to 0W-40 instead of 10w30. It's just a better oil. The Mobil 1 ESP 5w30 is a low SAPS oil. It's the closest thing to what you said you wanted - something that has HTHS of at least 3.5 and is also API SP compliant. The only reason why Mobil 1 ESP 5w30 is not API SP is that it's not an energy-conserving oil, however, I'm pretty sure that it beats any off-the-shelf 5w30 oil that you can get at Walmart.
Congrats on the new wheels. I'd stick with the Kia recommended viscosity, but I sure wouldn't dump synthetic oil every 3,000 miles. That's just wasteful. I'd do religious 5K oil changes and not worry about it.
I am going to UOA after the first couple of changes after the engine is done wearing in and see how the oil holds up.
Make sure to use a quart of Lucas Synthetic Oil Treatment with every oil change 😁 /s
Seriously though, let us know what you pick. Again, do a couple of quick oil changes to get out the metals. I did the first oil change on the Sonata at 3000 miles and regretted not doing it sooner. The filter was full of sparkly metals.
I originally was going to change at 1k, but arcographite said 2k. I have no idea if the factory oil has any break-in additives. If someone knows, please share.
One more thought... a jug of Supertech 5w30 should be fine for 100 miles right? just to get the last bits of metal out?
I'll buy what I'm going to run of course, but it seems silly to dump a Full Synthetic after 100 miles
One more more thought... I think this engine may have a variable oil pump... trying to confirm that. If it does, what does that do to my oil choices?
What's a jug of Supertech going to save you, $5~$7? Not worth it. I used Mobil 1 Extended Performance 5w30 in the Sonata for the 50 miles I did, just because thicker oil will carry more contaminants than a thinner oil. Then I went back to 0W-20. I would get a jug of Mobil 1 FS 0W-40 if I were you for $22 and dump it after 100 miles. If you like it, stick with it. The only reason I recommended Castrol EDGE 0W-40 was because it has lower sulfated ash, 1.1%, vs. Mobil's 1.3%. Or you could do 100 miles with Castrol EDGE 0W-40. Whatever oil you use, some of it will be left behind when you change your oil. That's why I didn't recommend Supertech. I mean, it's okay oil, but it's not for performance engines, that's for sure.
What's a jug of Supertech going to save you, $5~$7? Not worth it. I used Mobil 1 Extended Performance 5w30 in the Sonata for the 50 miles I did, just because thicker oil will carry more contaminants than a thinner oil. Then I went back to 0W-20. I would get a jug of Mobil 1 FS 0W-40 if I were you for $22 and dump it after $100. If you like it, stick with it. The only reason I recommended Castrol EDGE 0W-40 was because it has lower sulfated ash, 1.1%, vs. Mobil's 1.3%. Or you could do 100 miles with Castrol EDGE 0W-40. Whatever oil you use, some of it will be left behind when you change your oil. That's why I didn't recommend Supertech. I mean, it's okay oil, but it's not for performance engines, that's for sure.
That's fair enough, with the current rebates M1 won't hurt too much.
Any thoughts on a variable oil pump? I'm still trying to determine if the 2.5 has one or not. It looks like the 1.6 does.
Actually... I have 4qt of my Mobil 1 High Mileage 10w30 already. I'll just pick up one more jug and give it a test. Then I'll try the FS 0w-40 :D
Yes, it does have a variable oil pump, and for good reason.
I would just march the four quarts of Mobil 1 High Mileage 10w30 into Walmart, and at $9/quart, you can get almost two 5 quart jugs of Mobil 1 Full Synthetic 0w40 for that money. Or a 12-quart carton.
It's a 5qt jug with 4qt left in it.
I will try the FS 0w-40 after the 10w30. 100 miles is 3 work days for me, so it will probably be more like 180 miles. I have to go to my local dealer to buy filters.
if you’re not going to use EP’s long drain interval just use supertech or Quaker State Ultimate Durability.
pp, vanilla edge and m1 are generally overpriced
budget d1g2 oils, c3 oils and EP d1g2 oils
I don't know if saving a couple of bucks here and there on oil is really the way to go. I don't buy oil by the quart of course because that gets expensive fast. However, to it's worth spending $25 per 5 quart jug of Mobil 1 Extended Performance 0w20 as opposed to $19 for Quaker State Ultimate Durability. It's just a better oil, no question about it.
@SilverFusion2010 I think that this is the factory fill in your engine: https://www.shell-livedocs.com/data/published/en-US/0f0d9c18-b1e6-4d5f-9e18-c2d76fef1988.pdf
Ironically, it's an API SN ACEA C2/C3 oil. It's what they put in the Genesis turbos.
Leave it up to the Liberal Arts graduates to write Hyundai's owner's manuals, specifically the motor oil section 🤣
No, it doesn't ship with any kind of special oil or additives from the factory. Mass produced engines never do.
Thanks for this. At 11.9cst hot this oil is very close to the Mobil 1 High Mileage 10w40 and Mobil 1 Full Synthetic 0w40. I doubt I’ll be able to tell the difference.
bought some oil filters at the dealer yesterday. I’ll take pics of the sparkly oil filter when I change it.
You could just use the same oil as the factory fill: Pennzoil Euro LX 0w30 of it's Quaker State doppelganger. It's actually really good stuff. There is a used oil analysis somewhere here from a guy who ran it for 10K miles in a Alfa Romeo Giulia (Turbo) and had very little a wear metals and no shearing whatsoever. It's great stuff.
