Dr. Haas, you no doubt are the premier advocate of thinner weight oils at this site.quote:
The viscosity IS too thick at start up. One of the mandates of the SM rated oil is to provide thinner oils for the start up period. This is not meaning for minus 30 degree weather but for normal everyday use at start up.
How does the API SM service grade mandate thinner oils for the start-up period?
Low temperature (-30C to -40C) pumping viscosity is addressed by Sequence IIIGA with a ASTM D-4684 test run with the end-of-test sample from the Sequence IIIG test.
But the intent is to limit damage from oils that don't pump in very cold, subzero temperatures.
The SAE J300 viscosity chart remains the same for API SM.
Which Sequence or ASTM test are you referring to?
