- Joined
- Feb 6, 2025
- Messages
- 115
Hey everyone, I’ve been digging into engine wear patterns and wanted to get your thoughts. Conventional wisdom says most wear happens during cold starts due to oil starvation, but I recently came across a video that challenges this (linked below).
MOD - Link to video removed IAW BITOG rules on profanity.
The guy tested 50 oil filters (25 pre-filled, 25 dry) and analyzed wear metals via oil samples. Surprisingly, there was no measurable difference in bearing wear between pre-filled and dry filters. He cited SAE studies suggesting engines wear most during warm-up, not initial startup. The reasoning? Components like piston rings and cylinders expand as they heat, creating friction until oil reaches optimal viscosity and pressure stabilizes.Key takeaways from the video:
- Bearings showed minimal wear regardless of filter prep.
- Oil analysis revealed iron (from rings/cylinders) far outpaced lead (bearings) in wear metals.
- SAE papers from 1953–2006 consistently tied peak wear to thermal expansion phases, not cold starts.
