I went to change the oil on our 2024 Kia Seltos SX today and noticed that the Fram filter I purchased doesn't look exactly like the filter that I removed. The oem filter has a plastic cage on the bottom that I guess can allow the drain plug to rotate around the filter housing as it's tightened. The oem filter is slightly taller also because of the plastic cage.
Does anyone know if the Fram is okay to use or should I wait and pick up a filter at the dealer tomorrow?
