Bought new and Oil/filter changed at 1K miles and then every 4-5K miles (Toyota recommends 5K). All other maintaince performed per manufactures recommendation. It's a Toyota 4.7 V8. I'm using dino oil Castrol GTX 5w30 which meets the spec's recommended by Toyota and the Toyota OEM oil filter. Normal miles driven per year is 18-20K and most trips are between 5-15 miles each direction. Vehicle is kept in a heated garage in the winter. How many miles do you think this engine will run before it needs to be overhauled?
